needs some help please
Thread begun 5/18/2012 2:07 pm by akstudio | Last modified 5/21/2012 2:31 pm by akstudio | 4277 views | 8 replies |
akstudio
Im going nuts here. Here is the basic flow of data:
admin logs into backend. fills out a form. This form has a file upload and 4 check boxes. each checkbox is equal to a user level. This allows me to display the file based on user level. Some files may be seen by more than one user level.
my table is as:
table name: policies
id
file_name
1
2
3
4
each number represents a user level
when a file is uploaded and tagged as 3 for example, the data in the "3" field is either 1 or 0.
Now, what I want to do is to display all file_names in 3, that are 1.
Makes sense?
To make matters more complicated, I think I need to define it by '$_SESSION[user_level]'.
I have no idea who to do this. I have tried a ton of things. The closest I have come to is:
$SQL = "SELECT * FROM policies ";
if($_SESSION['user_level']== 1)
$SQL = $SQL . "WHERE 1='1'";
if($_SESSION['user_level']== 2)
$SQL = $SQL . "WHERE 2='1'";
if($_SESSION['user_level']== 3)
$SQL = $SQL . "WHERE 3='1'";
if($_SESSION['user_level']== 4)
$SQL = $SQL . "WHERE 4='1'";
echo $SQL;
But I still only get one file back, and its usually the first record in the table, doesnt matter if its 1 or 0
This is way out of my league now.. is there an easy way to just : select all "1's" from my table, based on you is logged in?
CraigRBeta Tester
post a copy of your table and what you expect to see from a pseudo query.
Normally, to filter, your query should be something like...
"SELECT * FROM tablename WHERE fieldname = 'some criteria' "
btw * is lazy, you should only realy select the fields you want to see, but it will get you started
If your query is working ok, you should be able to see the values returned when you test the recordset in dreamweaver.
If this is Ok, then perhaps you have a problem with your repeat region
gruant2000381341
you need a loop to gather all the results
I don't know your table fields so I just used name, fileName, and date
then I echo out the $dynamicList in your page body
session_start();
// determine which query value based on session
if (isset($_SESSION['user_level'])) {
if($_SESSION['user_level']== 1) {$ul = 1;}
if($_SESSION['user_level']== 2) {$ul = 2;}
if($_SESSION['user_level']== 3) {$ul = 3;}
if($_SESSION['user_level']== 4) {$ul = 4;}
//run query
$sql = mysql_query("SELECT * FROM policies WHERE $ul='1'");
//initialize
$dynamicList = "";
//get count
$numRows = mysql_num_rows($sql);
//see if any returns
if ($numRows < 1) {
$dynamicList = "Nothing to show";
//if results start loop
} else {
while($row = mysql_fetch_array($sql)){
$name = $row["name"];
$fileName = $row["fileName"];
$date = $row["date"];
$dynamicList .= '&nbsp;&nbsp;' . $name . '&nbsp;&nbsp;' . $fileName . '&nbsp;&nbsp;' . $date . '<br />';
//display the list
echo $dynamicList;
akstudio
Thanks guys..
I tried gruant2000381341 suggestion... it kinda works.
...$sql = mysql_query("SELECT * FROM policies WHERE $ul='1'"); .... that $ul='1' needs to be like the session var.
when I log in using the code above, as user_level 2 .. it tells me "nothing to show" .. if i change the select to .... $ul='2' ... then it shows ALL results .. weather intended for that user level or not.
This is my current code.
<?php require_once('Connections/conn_resellers.php'); ?>
<?php require_once( "webassist/security_assist/helper_php.php" ); ?>
if (!WA_Auth_RulePasses("Logged in to users")){
WA_Auth_RestrictAccess("login.php");
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
// EVENTS SELECT
mysql_select_db($database_conn_resellers, $conn_resellers);
$query_events = "SELECT * FROM events";
$events = mysql_query($query_events, $conn_resellers) or die(mysql_error());
$row_events = mysql_fetch_assoc($events);
$totalRows_events = mysql_num_rows($events);
//session_start();
//run query
//initialize
$dynamicList = "";
//get count
if ($numRows < 1) {
$dynamicList = "Notta";
} else {
//$name = $row["name"];
$filename = $row["file_name"];
//$date = $row["date"];
$dynamicList .= '&nbsp;&nbsp;' . $filename . '<br />';
//display the list
<body>
<?php if(WA_Auth_RulePasses("authorized")){ // Begin Show Region ?>
<p>#2 Authorized rule shown</p>
<div class="policy-list"> <?php echo $dynamicList; ?> </div>
<?php } // End Show Region ?>
</body>
Here is the DB:
CREATE TABLE `policies` (
`id` int(10) unsigned NOT NULL AUTO_INCREMENT,
`file_name` varchar(45) NOT NULL,
`1` varchar(45) NOT NULL DEFAULT '0',
`2` varchar(45) NOT NULL DEFAULT '0',
`3` varchar(45) NOT NULL DEFAULT '0',
`4` varchar(45) NOT NULL DEFAULT '0',
PRIMARY KEY (`id`)
) ENGINE=InnoDB AUTO_INCREMENT=14 DEFAULT CHARSET=latin1;
that 1, 2, 3, 4 is equal to the user_level.
gruant2000381341
thats odd because you shouldn't have any 2's in the db, only 0 or 1 ..right?
maybe instead of having 1,2,3,4 columns with a 0 or 1 have one column named user_level with an enum of 1,2,3,4 default of your lowest level or even a zero
then you could change that query to
$sql = mysql_query("SELECT file_name FROM policies WHERE user_level='$ul'");
also, just to do a tiny bit of db optimization..
if those are only ever going to be a 1 or a 0...you don't need a limit of (45)...change that limit to (1)...or go with enum '0','1'
akstudio
I'll keep trying your method as stated above. The issue I am having is that each file name may be viewed by more than one user group. It will be uncommon, but there will be occurrences. Otherwise, your second suggestion would work out well.
I think thats where alot of my confusion comes in, when I need one file to be seen by several groups.
akstudio
the statement, I would believe, should kinda be like:
$sql = mysql_query("SELECT * FROM policies WHERE '$_SESSION[user_level]' = '$ul'");
But this, again, spits out all the records.
When I login as, lets say, user level 2... there should only be 3 files available for me. but instead, it lists out the entire db.
i would do this a completely different way.
I would use three tables to create a many to many relation of files to user groups:
files:
fileID - primary key
fileName - varchar
usergroups:
userGrouplID - Primary Key
userGroup - varchar
usergroupfiles:
usergroupfileID - primary key
usergroupfileFileID - relates to files.fileID
usergroupfileGroupID - relates to usergroups.userGrouplID
then you can use a join query to get all files that belong to a specific user group:
SELECT files.fileName
FROM files
INNER JOIN usergroupfiles
ON usergroupfiles.usergroupfileGroupID = files.fileID
WHERE usergroupfiles.usergroupfileGroupID = paramID
variables:
type: integer
default value = -1
run time value: $_SESSION[user_level]
akstudio
That method looks cool to, thanks.
I will report that I FINALLY got it to work...
I had to go into the db and change the 1,2,3,4 to userlevel1, userlevel2, etc.... then select:
$sqlquery = "SELECT * FROM policies WHERE UserLevel" . $_SESSION['user_level'] . "='1'";
Thanks a ton guys... i feel i can now move on =)
