Complete sites w/ other WA products
Thread begun 7/30/2009 4:57 pm by Brad Lawryk | Last modified 7/31/2009 7:48 am by Ray Borduin | 3501 views | 4 replies |
Brad Lawryk
Hi guys,
(You'll be sorry I found these forums)
Ok, so now I have the Design Suite to go with the Developer Suite I already had ... what I want to do is create a complete website complete with features from other products that I will need to reuse the same design (but with different graphics and colors) over and over for several sites.
Can this be done or do the other products have to be added in after the design each time? (search, data administration for examples)
Brad
Dani Chankhour
As far as using the same design, you could accomplish this using CSS Sculptor, CSS Menu Writer and Site Assist Professional to create a template site that could be used for multiple sites. As far as adding the functionality to the admin and search page, you will need to apply these separately for each site, since you database structure could be different on different sites.
I don't see why you couldn't do that. For instance our powerstore we designed in that way using our products.
Brad Lawryk
Basically the idea is that I have say 8 Lacrosse Teams in our league. Every team will use the same exact layout and data structure. Only thing that changes from site to site would be the graphics and colors.
Brad
That is very common and should not be a problem. You just copy the database and the site to another server and update the images, graphics, and colors usually from the template.
