Date Picker
Thread began 5/18/2012 1:23 pm by jo271221 | Last modified 5/21/2012 7:14 am by Jason Byrnes | 880 views | 1 replies |
jo271221
Date Picker
Can you select initial values for the datepicker? ie todays date on insert form and retain entered value on update forms?
If so, is there help documentation on this?
Also when I inserted the datepicker it did not appear until I click in the form field - I am not sure the user would know to do that, but I guess they would try. Is there suppose to be a calendar icon?
Thanks,
to use the current date for the insert form, set the value of the date picker element to use the date() function:
value="<?php echo(date("m/d/Y")); ?>"
for the update form, set the value to use the recordset binding for the date column:
value="<?php echo $row_recordsetName['HistoryDate']; ?>"
Yes, the datepicker is supposed to trigger when the user selects the date field for input, no, there is not supposed to be a calendar icon.
