Loading Problem in CS6
Thread begun 5/17/2012 4:17 am by drubin312804 | Last modified 6/24/2013 7:25 am by Jason Byrnes | 6194 views | 9 replies |
drubin312804
I've upgraded to CS6 and added my Web Assist Extensions into the CS6 Extension Manager, however when I try to use the Web Assist Extensions I get the following message and then the Web Assist shuts down:
Error in serialCheck
ReferenceError: WA_addMacPath is not defined
at this time, only eCart5, Design Extender and Data Bridge are compatible with Dreamweaver CS6.
In the coming months we will be evaluating the rest of the stand alone extensions for compatibility, but this will take some time get through the entire catalog.
if you need to use CS6 now, I recommend upgrading to Data Bridge and Design extender.
biz295654WebAssist
Unless you are Mac.
johnatcreps433768
Originally Said By: Patrice
  Unless you are Mac.
that means they dont work with Mac?
MBas36765805
irrelevant comment!
f.v.bragt428438
What is the status of the CS6 compatibility now, early July, regarding stand alone extensions?
Thanks,
Frans
johnatcreps433768
i just upgraded to Data Bridge and Design extender, still get same msg: Error in serialCheck. please help.
Did you uninstall the stand alone extensions from the extensions manager before installing Data Bridge and design Extender?
Data Bridge and Design Extender replace the stand alone versions, so the stand alone versions need to be uninstalled first, before installing Data Bridge and aDesign Extender.
MBas36765805
Please post good solutions. I don't want this beatiful webasite goto waste.
You guys are not offering a good solution other than cheat chat.
@MBas36765805:
What is the problem you are encountering?
I have not seen you ask a question in this thread. I have only seen you comment that someones else's reply was irrelevant.
If you are having a particular problem, please let us know what it is.
You say we are not offering good solutions, but do not comment on what you want us to solve?
This thread is in regards to DW CS6 compatibility. The CS6 compatibility solution is to install eCart 5, Design Extender, Data Bridge and Free Tools. These are the extensions that are updated to work with DW CS6.
I'm not sure what "cheat chat" means, but the suggestion to install the extensions that are compatible with DW CS6 to address CS 6 compatibility issues is the solution, if you are asking about CS 6 compatibility.
