Help with some code, please
Thread begun 5/16/2012 1:33 pm by msummers194171 | Last modified 5/25/2012 10:30 am by msummers194171 | 5208 views | 11 replies |
msummers194171
I have a select tag on an update page created using DataBridge and I want it to load showing the properly selected value from the database. It's not doing that.
The code is this:
<option value="">Select Project Category</option>
do {
<option value="<?php echo $row_WADAproject['project']?>"<?php if (!(strcmp($row_WADAproject['project'], (isset($_GET["invalid"])?ValidatedField("projectsupdate","project"):"".$row_WADAprojects["project"]."")))) {"selected=\"selected\"";} ?>><?php echo $row_WADAproject['project']?></option>
} while ($row_WADAproject = mysql_fetch_assoc($WADAproject));
Basically, I need you to explain this code and how it works.
How should I change that code so that the selected="selected" is properly shown when the original value/validated value equals the current value of $row_WADAproject['project']?
send a copy of the page so i can see the code in context please. i need to see the recordsets being created as well as the list code.
msummers194171
Thanks, Jason....
this is a badly set up page and a badly set up database.
it looks like you are trying to store it looks like your select list is a multiple select list which would mean that projects are stored as a comma separated list to the database.
this is a bad practice. this is not the correct way to create a many to many relationship
your project categories should be in it;s own table:
categories:
categorieID - primary key
categoriesName - varchar
the categories table should be used to populate the list.
Should the category select list be a multiple select List? or should a project belong to only 1 category?
If the project should belong to only 1 category, then you can use a standard insert to the products table, and store the category ID.
if a project can belong to more than 1 category, then you are trying to create a many to many relationship, and will need a 3rd linking table:
projectcategories:
projectcategorieID - primary key
projectcategorieProjectID - relates to project.id
projectcategorieCategoryID - relates to categories.categorieID
and you will need to use the manage relational table behavior to assign the categories to projects.
msummers194171
Nope, that's not how it is at all.
The projects records each include a project category field as an enum field. I have a recordset on that page that does a SELECT DISTINCT on that field - thus, the recordset ($row_WADAProject) thus contains a single instance of each project category. This recordset is used only to populate that select tag. As I'm stepping through that recordset I want to compare each project category to the category in the record specified by the passed ID, and when they match, add the "selected" attribute to the associated <option> tag.
Each project in the projects table will belong only to a single project category.
Does that help you understand what I am doing? I want a list of categories with the category applicable to the given record already selected.
msummers194171
Thank you, Jason.
msummers194171
Jason - under the general subject of 'help with some code', can you please explain to me this line of code? It's taken from a radio button group created with DB:
if (array_search("1", ((isset($_GET["invalid"]) && ValidatedField("projectsupdate","display"))?ValidatedField("projectsupdate","display"):array())) !== false
My interpretation of this is the following - just tell me if I am correct.
When a field fails validation, the form needs to know whether to display the data in the database or the newly submitted data as the page refreshes and to do that the form submits to itself with a url variable of "invalid". So that line is testing whether it's the current field that failed validation or not (in this case that field is named 'display'). If it did fail validation, then the database data is shown, and if it did not fail validation then the (valid) submitted data is shown. I think I have that right....
What puzzles me is that the false part of the ternary operator is just an empty array. Why is that?
So, breaking it down:
isset($_GET['invalid']) - this is true when there is a field in the posted data that fails validation.
ValidatedField("projectsupdate","display") - I'm not exactly sure what this does, but it's always null for this 'display' field.
in this case, these two tests both fail, meaning that the ternary isset($_GET["invalid"]) && ValidatedField("projectsupdate","display"))?ValidatedField("projectsupdate","display"):array() will always return (for this particular field) the "false" result, i.e., array(). But that array is completely empty!
Since the array is empty, the test array_search("1",array()) will always fail, and so 'checked="checked"' will never get written. And this is in fact the case - that radio group is not populated when the update page loads.
My conclusion is that an empty array at that point is an error. I don't know whether it's my error (although I haven't hacked this part of the code at all) or DB's error.
Sorry this is so long-winded, but it will sure help me understand the code to get your thoughts....
the validated entries collection returns any valid form data when the form fails validation.
you assessment of the code is correct, though I think it would only be using an array search for a multiple select list, or checkbox group, not for a radio group which can only ever have one item checked.
msummers194171
Jason: It seems that would be the case for a radio group, but I have just verified on a test page that this is the way the code is inserted - a blank array - when you create a DA form with only a radio group. Please try that - it must be a bug.
In fact, I can make that block of code work by inserting a single value into that empty array:
ValidatedField("projectsupdate","display"):array($row_WADAProjects['display'])))
With that code, the radio group is shown properly populated whether its value is yes or no.
