Only showing last record from recordset
Thread begun 5/15/2012 3:17 pm by rabb | Last modified 5/16/2012 7:02 am by Jason Byrnes | 2339 views | 3 replies |
rabb
I have just started using the maps extension tonight but run into a problem.
The recordset I have setup shows all records, however, when I check the "Show multiple" box and view the map, I only see the last record pinned on the map.
Is there an easy fix for this?
My environment is as follows:
Dreamweaver CS6
WAMP (V2.2) apache mysql server running on spare XP pro box.
Thanks,
Rab
please send a copy of your page and the google_javascript folder so i can examine the code.
also a link where I can see the problem.
rabb
Hi Jason,
Thanks for the quick reply. See attached file for code. The server isn't available to the outside world unfortunately.
