Error during Site Sculptor add CSS menu
Thread begun 5/15/2012 12:41 pm by elevy388997 | Last modified 5/17/2012 1:38 pm by Jason Byrnes | 2242 views | 4 replies |
elevy388997Beta Tester
Upon installing design extender and trying to make a site sculptor site, I get the attached error upon selecting a css menu writer menu to go on the page.
Also, should I still be placing forum posts in the respective areas (such as this is Site Sculptor)? Or are the forum areas for the older, non designer extender, versions?
before starting the Site Sculptor wizard, you should have a page from your site open, This error sounds like it would happen if a page from your site is not open first.
I think if you are using Design Extender, it would be best to post your questions in the design extender forum, but make sure to include that you are using the Site Sculptor portion in your subject line:
Site Sculptor - Rest of subject
or you can post to the individual forums as well, but make sure to include in your message that you are using Design Extender.
This happens when I am in Preset Manager trying to setup the site sculptor site design. I am not even trying to create the actual pages yet.
Here is a larger view of the error. As you can see all I do is open up the preset manager, go to site sculptor designs, and try to go through the wizard. I can select the menu but as soon as I click for "navigation" to be the menu, the error pops up. I click ok, then it pops up again, i click ok, then it goes away.
Can I just click past it for the time being?
Dreamweaver CS6 - Design Extender 1.06
I have recreated the error and have logged it as a bug in our system, it will be corrected in the next update that we release, we should be releasing an update in the next week or 2.
