Searching Dates
Thread begun 5/15/2012 1:17 am by salaroche | Last modified 5/16/2012 11:43 am by Jason Byrnes | 1703 views | 3 replies |
salaroche
Searching by Date Range
Hi:
Just wondering why I can't get the right results when doing a search based on dates. The format my DB demands is yyyy-mm-dd and that's the format in which I enter dates in the search form, but I don't get the right results or I get none.
Any sugegstions? Attached please find the search and results pages in question.
Thank you for your attention.
to help troubleshoot, add the following code just after the <body> tag:
<?php echo("SQL: ".$query_limit_WADAoxadmain.""); ?>
and provide a link where i can see the problem, and an example of a search you are doing that is not returning the expected results along with a description of what the expected results are.
salaroche
Jason:
Thank you for your attention. I already solved this issue. For whatever reason, the second parameter in the date-range search, the form field "paymentDue2", was not appearing on the Wizard's list, so it was only searching using the first of the range parameters twice, which was obviosuly anulling most of the searches.
I just added the second parameter manually and it all seems to be working fine now.
OK, glad to hear you found the problem.
