contact form not working
Thread begun 5/14/2012 12:51 pm by johna1964 | Last modified 5/14/2012 2:34 pm by Jason Byrnes | 3171 views | 5 replies |
johna1964
The contact page is not working at all. It doesn't even refresh correctly. It was working just fine a week ago.
Can you see anything that would cause this to happen?
Thank you!
johna1964
my guess would be a problem with session variables.
I bet the host updated the PHP server on your site.
use the session test script from the following post to test the servers session management:
showpost.php?p=23826&postcount=2
If the session test fails, it is a problem with the session.save_path setting in the php.ini file.
johna1964
Hi Jason,
If this is what I was supposed to do, this is what happened:
1) Uploaded the file to the server
2) Arrived at the page by adding sessionTest.php in the address bar
3) When loaded, the links appear as visited; there is no test=null upon loading
4) When clicking the first link - sessionTest.php?test=test appears in the address bar
5) When clicking the second link - only sessionTest.php appears in the address bar
The page says when the second link is clicked it should still be: sessionTest.php?test=test
So there is a problem?
also the captcha is again appearing that it does not validate - i made the changes and it worked now it's not again...
thank you for your help!
johna1964
send a link to the session test page.
johna1964
here's the link:
sessionTest.php
ok, the session test is passing.
