design extender upload not working
Thread began 5/14/2012 10:47 am by randyw2394710 | Last modified 5/16/2012 7:27 am by Jason Byrnes | 1063 views | 3 replies |
randyw2394710
i created upload section and there seems to be file missing it doesnt create
Warning: require_once(../webassist/file_manipulation/helperphp.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/96/8026696/html/admin_cms/gallery_Insert.php on line 7
Fatal error: require_once() [function.require]: Failed opening required '../webassist/file_manipulation/helperphp.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/96/8026696/html/admin_cms/gallery_Insert.php on line 7
<?php require_once("../webassist/file_manipulation/helperphp.php"); ?>
I'm not sure why that file is not being created for you, I have not been able to reproduce a situation where that file is not created. I will continue trying to find out why it may not have been created, in the mean time, here is a copy if the file for you to put in your site.
helperphp.php.zip
randyw2394710
Just so you know, the buttons used for help next does not show does that help
I'm not sure which buttons you are referring to. can you send a screen shot please.
also, what is your OS and DW Version.
