Encapsed error with Security pages
Thread begun 5/14/2012 9:40 am by msummers194171 | Last modified 2/10/2015 11:12 am by john70964 | 5786 views | 11 replies |
msummers194171
I have created Security Pages with DataBridge's Security Assist for login. When I then browse to the login.php page, I get this error thrown:
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in /home2/autores/public_html/webassist/security_assist/helpergroupsrulesphp.php on line 8
Line 8 is this -
$comparisons[0] = array(TRUE, "<?php echo ((isset($_SESSION['SecurityAssist_id']))?$_SESSION['SecurityAssist_id']:""); ?>", 2, "");
(those are all double quotes except for the ones within the square brackets)
Any ideas?
line 8 should be:
$comparisons[0] = array(TRUE, "". ((isset($_SESSION['SecurityAssist_id']))?$_SESSION['SecurityAssist_id']:"")."", 2, "");
not sure why it;s not being written correctly. What version of Dreamweaver are you using? and what is your OS?
msummers194171
That certainly looks better. I'm using CS6 on W7-64bit. All of the lines in that helper file 'switch' block are malformed as I showed for line 8. I guess I'll fix them all.
I have not been able to reproduce this, I will keep trying to find a cause.
msummers194171
Fixing those lines did allow the login page to load and function without error. Pretty odd....
Steve
I'm getting this same error.
Here is the source of a test page:
error_reporting
(E_ALL);
ini_set('display_errors''1');
 <?php require_once( "webassist/security_assist/helper_php.php" ); ?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Untitled Document</title>
</head>
<body>
<p>some stuff </p>
<p><br />
  <?php if(WA_Auth_RulePasses("UserLoggedIn")){ // Begin Show Region ?>
    some other stuff
    <?php // End Show Region ?>
</p>
</body>
</html>
Error:
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in E:\Websites\cmhi.org\htdocs\webassist\security_assist\helpergroupsrulesphp.php on line 34
Steve
Found part of the problem in that there are legacy directories such as WA_SecurityAssist...
Found the rule that is throwing the error and fixed the noted problem:
case "UserLoggedIn":
            $comparisons[0] = array(TRUE, "".((isset($_SESSION['SecurityAssist_UserID']))?$_SESSION['SecurityAssist_UserID']:"")  ."", 2, "");
            break;
Wrote me own that works:
<?php if (isset($_SESSION['SecurityAssist_UserID'])) { ?>
          Logged In &nbsp; &nbsp;
          <?php } else { ?>
          <a href="../access.php"> Member log in</a>
          <?php ?>
but would be interested in why the other does not work. Basically looking that IF the Session is present, they are logged in and show the content.
I dont see why that rule would not work, the code looks correct.
can you send a copy of the webassist\security_ass ist\helpergroupsrulesphp.php file so i can see that line in context please.
Steve
Please find attached the document you requested.
line 34 is exactly the same as line 28 and line 26, i don't see any issue, i don't see why the error would occur at line 34, but not the other 2 lines.
do you have a link where i can see the problem.
if you have a page that shows the problem, i can start an incident to look at it and find the cause.
