Javascript error on DWVR launch after 1.0.6 update
Thread begun 5/13/2012 8:32 pm by dan317597 | Last modified 5/17/2012 12:20 pm by dan317597 | 2185 views | 3 replies |
dan317597
Since I installed Design Extender 1.0.6 update, every time Dreamweaver launches, it reports the following JavaScript error:
"At line 21 of file "<path-to-config>:Floaters:WA_SiteTools_ProgressV2.js": theDOM.serverModel has no properties"
Fix?
Thanks,
Dan
Delete the Dreamweaver Cache file from the users configuration folder:
Andrew Dodd - ADDIGITAL
Problem solved - I think!!
I did this and it had no effect.. Any other suggestions?
Andrew
dan317597
Second tip did the trick
Just a follow-up here: Deleting the cache file didn't stop the error for me either, but I went back and read the "sticky" post from Jason about v. 1.0.5 issues ("Design Extender 1.0.5 has been released") and tried the last trick he lists:
  this can be corrected by resetting the workspace layout:
Window -> Workspace Layout -> Reset 'your workspace'
Actually, I couldn't resist taking a few extra steps, and maybe they are inconsequential, but I'll report: I switched back and forth to a few of the preconfigured workspaces, reset once again, deleted the newly-created cache file, then relaunched.
No error message!
Thanks all!
- Dan
