Problems with SA generated menus
Thread begun 5/13/2012 7:24 am by evansg7124312885 | Last modified 5/14/2012 7:40 am by Jason Byrnes | 1127 views | 1 replies |
evansg7124312885
In the pages wizard, I set to DB fields for menu. The wizard runs to end and pages are created, but in the register and user update pages where the menus appear, I have the following problems with both menus:
1: There is no visible spry validation message, both of these menus were set to required in creation.
2: The selected values are not inserted into the new record from the registration page and do not update from the update page. The menus appear correct in their pages and the Dynamic Dropdowns is working as expected. I did go through the Insert Record behavior, bindings appear correct. I am guessing that since it appears to pass server validation, that the value is retained initially.
All other entries in form are text boxes and do operate as expected, this problem appears to only apply to menus.
I did have this same problem in Security Assist before upgrading to DataBridge, work around was to insert new menus and delete the wizard created menus.
I am working with DW 5.5, Mac OS Lion, and DataBridge 1.0.2.
