2 eCart errors: Dynamically-related files error and Syntax error
Thread begun 5/13/2012 6:17 am by robvoigt9434728 | Last modified 5/15/2012 10:08 am by robvoigt9434728 | 2184 views | 4 replies |
robvoigt9434728
Hello, I have two eCart errors after creating my cart and add to cart buttons. The eCart object, cart and buttons have product options.
First error is the Dynamically-related files error. Can this forum take a look at that issue?
Second error is the syntax error on line 19 of the page: eCart1_PHP.php. Here is line 19 code: if ((strcmp($this->Items[$n]->ID, $itemID) === 0) AND (strcmp($this->Items[$n]->Name, $itemName) === 0) AND (strcmp($this->Items[$n]->Description, $itemDescription) === 0) AND (strcmp($this->Items[$n]->Thumbnail, $itemThumbnail) === 0) AND (strcmp($this->Items[$n]->Handle Color, $itemHandleColor) === 0) AND (strcmp($this->Items[$n]->End Cap Color, $itemEndCapColor) === 0) AND (strcmp($this->Items[$n]->Rope Length, $itemRopeLength) === 0)) {
Can you help with this?
the Dynamically-related files error is a dreamweaver warning and not really an error, it only means that dreamweaver is having a problem locating some include files. it is not really a problem to be concerned with unless you are getting an error that files cannot be found at run time.
for the second issue It looks like you have column names in your cart object that have spaces in the names. You should not use spaces in the eCart column names.
robvoigt9434728
OptionID is displaying, not the OptionName
Thanks that helped clear up the Syntax errors.
I have another question for you so thanks for taking a look at this:
When viewing my cart, the OptionID is displaying, not the OptionName.
Could you tell me which server behavior or other code I need to edit?
do your options effect price?
If the options do not effect price, edit the select lists. in the select lists, set the value to use the option name column instead of the option id column.
robvoigt9434728
No price increments and thanks that was it!
Getting close to done with this but I might have a couple other quick questions so thanks in advance for your replies.
