New Issue?
Thread begun 5/12/2012 8:49 am by bill173836 | Last modified 5/15/2012 1:52 pm by Jason Byrnes | 1786 views | 3 replies |
bill173836
New Issue?
When using the Database creation adding more than 1 dynamic menu crashes DW 5.5 or a Mac. When creating the second dynamic menu the window opens for a second with the previously coded menu then crashes.
I'm sorry, i', not sure I follow what you mean, can you provide more details on the steps you are following that lead up to this issue so i can try to reproduce.
bill173836
When going through the process of Configuring Field Settings. Let's say you add 2 dynamic menus one for sizes and one for color. You can create the first menu with dynamic data from you database with no problem. But when you try to create the second menu instead of a fresh creation window the data chosen for the first menu populates the second menu for a second or two then crashes dreamweaver.
I have reproduced this issue and logged it in our system so it can be corrected in the next update to be released, thanks for reporting this issue.
