Cannot activate
Thread began 5/11/2012 11:17 am by Peterson Design Studio - jefferis | Last modified 5/11/2012 1:34 pm by Peterson Design Studio - jefferis | 1542 views | 6 replies |
Cannot activate
Hi, I installed Databridge into CS 5.5 because of the problems with DWCS6, but it is telling me it cannot be activated, even though the serial number checks out. Have you installed some limitation on activations? I have a problem with this in 2 areas: multiple DW installs as above, AND my DW on my laptop for travel. Only using one copy at a time...
Now I cannot use DB or work on my sites...
ERROR 18
Weird. I clicked on a UE Server behavior and was able to activate it. But the insert record behavior gave the error.
do you still have data assist 2 installed?
are you able to use the insert record behavior now?
Bad Crash when closing the extension. Not sure what happened. DA is NOT installed. But it called up a DA panel when I tried to modify the behavior.
crash.txt.zip
This crash happened when trying to add dynamic connection for uploaded images to the email.
I am looking at the help file but do not see enough information. If I want to allow a visitor to send 4 images via Email, but not upload them for storage to the DB, there are 3 options: a dynamic connection or folder , recordset loop, and a submitted button that says Add Image.
When I try to attach a dynamic connection, I connected to the Add Image in the >Form rather than dynamic field Add_Image_Filename, e.g. And it crashed.
Yet when I leave it as, the images don't get sent.
if you are not uploading the files, then select the Submitted File.
you will need to click the plus button to add an attachment for each file field.
And Screen Redraw and responsiveness is VERY Slow with Databridge and Design Extender installed in CS 5.5 WOW
