Using the Update record wizzard for updating worldpay payment response
Thread begun 5/10/2012 11:10 am by bill3786 | Last modified 5/18/2012 9:20 am by bill3786 | 6905 views | 13 replies |
bill3786
Is it possible to use the Update Record wizzard on a new template generated page called wp_payment_response.php to update a column called WPtransID in the orders table. This is to record the transId parameter returned by the Worldpay payment response.
The confirm page is set up to pass the OrderID to worldpay.
Cant seem to get the script provided by Airfox to update the table so trying to do it from scratch (this is on another thread called "Worldpay confirmation emails").
The worldpay payment response is enabled, password is set, payment response URL correctly added to worldpay merchant interface.
If this can be done this way please could you help with the steps required or is there another way.
The objective is to use the payment response to update the orders table with the worldpay transId and also to generate a UE email detailing the contents of the cart and other parameters to be sent to the customer and merchant.
yes, the DataAssist update record can be used for this.
first go to the bindings panel and click the plus button, select eCart -> Checkout -> Checkout form response.
from the gateway list, select World Pay.
this will add bindings for the wold pay past to the bindings panel.
in the update record behavior, you can set the key column to the order ID column and use the transID binding for the value.
bill3786
Ok thanks.
Is this the correct procedure to generate a page for capturing the worldpay payment response?
1. Create a new page from the site template and add a database connection.
2. Use the update record wizzard as you describe.
3. Use UE to set up the automatic generation of the shopper and merchant email confirmation to show the email friendly cart details and add other bindings using the "eCart_checkoutForm" bindings.
From your post in another thread is this the correct code for the email stuff.
<?php if ($_POST['callbackPW'] == "YOUR_PASSWORD" && $_POST[transStatus] == "Y") { ?>
if (!isset($_SESSION))session_start();
if ("" == "") {
//WA Universal Email object="mail"
set_time_limit(0);
<rest of code here> What is this, is this the UE code block?
<?php } ?>
Does the line <?php if ($_POST['callbackPW'] == "YOUR_PASSWORD" && $_POST[transStatus] == "Y") { ?> need to be added at the begining of the update record code block or is it added by the wizzard.
Is there anything else that needs to be added to the new page?
this page will never be seen by the user, so adding the template to it is superfluous.
other than that, you are on the right track
bill3786
Please could you clarify the entries for the update record behaviour
1st page
Trigger - any form post
Key column - OrderID
Value - what goes here, is it <?php echo ((isset($_POST["transId"]))?$_POST["transId"]:""); ?> or <?php echo $eCart1->DisplayInfo("ID"); ?> or something else?
Data type - numeric
2nd page
update values
only add a value to WPtransID column (WPtransID is new column in orders table for worldpay transId) and do not enter values for other columns. Is this correct?
value for WPtransID is <?php echo ((isset($_POST["transId"]))?$_POST["transId"]:""); ?>
data type - numeric
bill3786
Really struggling with this, been trying for days with different combinations but the two parts of the worldpay payment response page are not working.
1. the update record behaviour doesnt add the worldpaytransId to the orders table
2. the email friendly cart is not sent to the customer and merchant
Attached are the relevant pages.
At first I was using a template generated page but now using just a new blank php page for the worldpay response page.
Hope you can point me in the right direction here.
this line of code is not correct:
if ($_POST['callbackPW'] == "removed" && $_POST[transStatus] == "Y") // Trigger
it should be:
if ($_POST['callbackPW'] == "removed" && $_POST['transStatus'] == "Y") // Trigger
notice the difference in referring to the transStatus post element:
instead of:
$_POST[transStatus]
bill3786
1.I have corrected the line you gave but still no orders table update or email sent.
I have recreated the pages attached again with the dataaasist update record and UE behaviours.
2. I noticed that there are a number of areas of text in the response page coding which display in black text as did the original transStatus. Is this significant?
3. Also after adding the UE the server behaviour was visible alongside the Update Record in the server Behaviours. But after adding the trigger stuff shown below, the UE behaviour disappeared thus not able to see to edit.
<?php if ($_POST['callbackPW'] == "removed for post" && $_POST['transStatus'] == "Y") { ?>
if ("" == "") {
4. Lastly I added the recipient for the email confirmation as eCartCheckoutForm_email. Is this correct?
how are you testing this?
have you set up your account with world pay to pass the response to the page you set up? if you are not sure how to do that, you should contact world pay.
from what I can see the page seams to be set up correctly, but if you have not set your account to send the post to this page, then nothing will happen.
bill3786
I am getting the worldpay standard emails to the shopper and merchant on each test purchase I do. I have done many many of these over the last few days.
Also on earlier attempts I did not use DW for the formating of the email friendly cart on the response page and this returned all the parameters from worldpay in a blank email.
I'm pretty confident that the worldpay account is set up correctly or this would not happen, would it?
