errors update and en insert pages
Thread begun 5/10/2012 10:28 am by biesheuvel378713 | Last modified 5/15/2012 8:25 am by Jason Byrnes | 2797 views | 5 replies |
biesheuvel378713
I've created pages with the data assist wizard and in the insert page I get this messages after I pres insert:
2 times:
Notice: Undefined offset: 1 in C:\wamp\www\nokk\webassist\form_validations\wavt_scripts_php.php on line 670
2 times:
Notice: Undefined offset: 2 in C:\wamp\www\nokk\webassist\form_validations\wavt_scripts_php.php on line 671
And then the error:
Unknown column 'TexttestText' in 'where clause'
The update page gives me this errors:
2 times:
2times:
And then the error:
Unknown column 'TextmeindertText' in 'where clause'
If I comment out the unique field validation I won't get the notices but I still get the error:
I added the pages from the wizard...
on the insert page, change line 14 and 16:
$WAFV_Errors .= WAValidateUnique(("nokkdb"),$nokkdb,$database_nokkdb,"user","id","none,none,NULL","0","login_name","Text","".((isset($_POST["login_name"]))?$_POST["login_name"]:"")  ."",true,2);
$WAFV_Errors .= WAValidateUnique(("nokkdb"),$nokkdb,$database_nokkdb,"user","id","none,none,NULL","0","email","Text","".((isset($_POST["email"]))?$_POST["email"]:"")  ."",true,4);
$WAFV_Errors .= WAValidateUnique(("nokkdb"),$nokkdb,$database_nokkdb,"user","id","none,none,NULL","0","login_name","',none,''","".((isset($_POST["login_name"]))?$_POST["login_name"]:"")  ."",true,2);
$WAFV_Errors .= WAValidateUnique(("nokkdb"),$nokkdb,$database_nokkdb,"user","id","none,none,NULL","0","email","',none,''","".((isset($_POST["email"]))?$_POST["email"]:"")  ."",true,4);
on the update page, line 14 and 16:
$WAFV_Errors .= WAValidateUnique(("nokkdb"),$nokkdb,$database_nokkdb,"user","id","none,none,NULL","".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"0")  ."","login_name","Text","".((isset($_POST["login_name"]))?$_POST["login_name"]:"")  ."",true,2);
$WAFV_Errors .= WAValidateUnique(("nokkdb"),$nokkdb,$database_nokkdb,"user","id","none,none,NULL","".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"0")  ."","email","Text","".((isset($_POST["email"]))?$_POST["email"]:"")  ."",true,4);
should be changed to:
$WAFV_Errors .= WAValidateUnique(("nokkdb"),$nokkdb,$database_nokkdb,"user","id","none,none,NULL","".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"0")  ."","login_name","',none,''","".((isset($_POST["login_name"]))?$_POST["login_name"]:"")  ."",true,2);
$WAFV_Errors .= WAValidateUnique(("nokkdb"),$nokkdb,$database_nokkdb,"user","id","none,none,NULL","".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"0")  ."","email","',none,''","".((isset($_POST["email"]))?$_POST["email"]:"")  ."",true,4);
biesheuvel378713
Thanks solved it for me.
But still this is annoying bug of the wizard. And I found an even more annoying bug. After reloading the wizard from a saved preset the field settings dialog keeps removing or adding the required validation randomly. It results in pages created by the wizard where the required vaidation is randomly put on to the form. Even after opening/editting the field settings dialog over and over again...
these are not issues I have been able to reproduce.
What version Of Dreamweaver are you using?
What is your operating system?
biesheuvel378713
I use Dreamweaver CS6 on a Win 7 64 bit system
I will start an incident so we can look into why these issues are occurring
