Dynamic Lists in Shopping cart - Only show if product offers option
Thread begun 5/10/2012 7:09 am by toni272059 | Last modified 5/14/2012 2:31 pm by Jason Byrnes | 4418 views | 7 replies |
toni272059
Store offers various products. Some of which offer embroidery for an additional fee.
The Product Detail page is where the customer adds the additional Embroidery fee (price increment) and it is added to the cart along with the product .
product_detail.php?ProductID=1
On the Cart page would like to add the Embroidery Selection process -- Eg select a Type, select a Style, enter the Letters. I have setup two dynamic lists and a text field. All inside a DIV inside the Repeat Cart Region.
Question -- how do I setup the Embroidery Selection DIV to only show if the Embroidery Option was added to the Cart on the Product Detail page? I tried adding a Show If but that just removed the DIV from all Items in the Cart regardless of selection on Product Detail page.
I have attached the cart.php
Next step -- will be to dynamically add the selected items to the Confirm Order page, upload them to the orders database table, and add them to the confirmation email. Any tips as to most efficient way to do this would be appreciated.
Thanks as always.
this should not be done on the cart page, the embroidery selection should be done on the details page. putting it on the cart page means that there is no way to store the selections to the cart object.
te embroidery selection need to happen on the product detail page so that when the item is added to the cart, the other selection will also be added.
the type style and and text all need to be columns in the cart object and need to be included on the product page.
toni272059
OK, so I moved the Embroidery Selection DIV out of the Cart and into Product Detail
product_detail.php?ProductID=3
Updated the eCart with columns. Selections successfully added from Product Detail to Shopping Cart
However, now the Embroidery Selection DIV appears on every Product Detail page regardless of whether embroidery is even an option for the product being purchased
How can I set it up to hide the DIV until the Embroidery ($15) item is selected from the Dynamic Select Menu?
Also, the Checkout button is no longer working. Cart appears to be redirecting back to itself (/cart.php?). The Continue Shopping, Clear Cart and Update buttons are all working correctly. There are no error messages.
//WA eCart Redirect Check Out
if (isset($_POST["eCart1_Checkout"]) || isset($_POST["eCart1_Checkout_x"])) {
$Redirect_redirStr="";
if ($Redirect_redirStr != "") {
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
if (strpos($Redirect_redirStr, "?") < 0) {
$Redirect_redirStr .= "?".$_SERVER['QUERY_STRING'];
else {
$Redirect_redirStr .= "&".$_SERVER['QUERY_STRING'];
$eCart1->redirStr = $Redirect_redirStr;
$eCart1->cartAction = "Checkout";
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
add the following script to the head:
function showHideEmbroideryOptions(optionIndex) {
if(optionIndex == '2') {
document.getElementById('embroideryOptions').style.visibility = "visible";
} else {
document.getElementById('embroideryOptions').style.visibility = "hidden";
</script>
change the style tag for the embroideryOptions div to include visibility:hidden;
<div id="embroideryOptions" style="margin-top:15px;padding:5px;border: 2px solid #C00;visibility:hidden;">
and add an onchange event to the embroidery select list:
<select name="eCart1_1_Embroidery_Add" onChange="showHideEmbroideryOptions(this.selectedIndex);">
the checkout behaivor code:
if (
if (isset(
if (
else {
does not set a redirect page, change:
$Redirect_redirStr="checkout.php";
toni272059
Thank you for the code to show/hide the embroidery depending on selection. Works great.
However, the redirect from Cart to Checkout is still not working. It has in the past. Still redirecting back to itself (.../cart.php?). I did update the code
else {
My next challenge is to have the Embroidery Selection choices Only show on the Cart page when they were selected on the Product Detail page.
I have been looking thru the forum, is this something I would do with SecurityAssist Show Region?
The Type and Style data comes from Dynamic Lists from separate recordsets, and the Text and Msg are each from an eCart Session Value so doesn't look as if a recordset Show If would work..?
Many thanks as always.
toni272059
I am not seeing a new ticket in my support history...?
thanks
I have recreated it, should be there now.
