CS6 Server Redirect Bomb Out
Thread began 5/09/2012 1:10 pm by Ian S | Last modified 5/11/2012 10:57 am by Ian S | 2310 views | 5 replies |
Ian S
Not sure if this falls under DE and DB, but every time I try to use the Server Redirect behaviour under CS6 on the MAC it crashes Dreamweaver.
This happens on any site, on a blank page or a page that has already been created.
The behaviour opens the window to select the trigger and it opens the file browser to select the destination, but when selecting the file it bombs before populating the behaviour window. Occasionally, it repeatedly asks me to select the file to redirect to before bombing out. Other times it just does it the once.
I have just have three WA extensions installed. eCart 5.04, DE 1.05 and DB 1.01 and have cleared the .dat cache file (yes, CS6 still has it!) :-)
Cheers
Ian
Edit: Just to add. I can add a dynamic value as a server redirect, but the bomb out occurs when I try to browse the file system. Cheers
Ian S
Just to add... I can manually type in the redirect destination and can apply the behaviour OK, its just when I go to browse the file system to select the file.
Cheers
Ian
we are looking into the cause of this right now and hope to have a fix for it in the next update, thanks for reporting this issue so we can investigate it.
Ian S
Thanks Jason,
Its actually not just the Server Redirect behaviour, its anywhere where you want to select a file for a redirect such as Insert, Update, Delete etc.
Also, even selecting Server Variables or Session Variables in the lightening bolt window doesn't always work first time (but at least it doesn't crash DW).
Cheers
Ian
This is a problem caused by a bug we have identified in DW CS6 on Mac OS, We will be releasing an update in the next couple of days to address the issue.
Ian S
Top man.
Thanks Jason!
Cheers
Ian
