ECart Help Needed
Thread begun 5/09/2012 12:48 pm by Steve E | Last modified 5/17/2012 1:58 am by Steve E | 6283 views | 12 replies |
Steve E
ECart Help Needed
Hi
I am building a shopping cart and am using PayPal checkout, every thing seems to be working ok after a few adjustments to the scripts generated by the latest ecart checkout wizard.
1/ I have noticed that if I place an second order within half an hour or so from the time of the initial order, the order ID is overwritten with the new details and the first order details are lost, I thought about killing the session but as I need to force the user to register at checkout this does not seem to be an option, any ideas on how to overcome this?
2/ I need to update my orders table with a value of 'Completed' I set an initial value of 'Pending' on the confirmation page, on my IPN page I have added a update record behaviour to change the value, this is not working and its getting pretty confusing, I'm sure I'm nearly there with it, but feel this is something I need to ask if you could take a look at to see what needs to be done.
3/ I would like to update the products table to deduct the quantities of the ordered products from the values stored in the products table, I haven't done anything with this as I feel I must get the status updating correctly first.
4/ I would like to display the details of the order on the checkout_success.php page, and send an email to the user when the page loads confirming the purchase and order details.
Any advice would really be appreciated, I have attached the files and will purchase a support ticket if needed as I have a deadline to meet and its fast approaching.
Thanks in advance
1) Add the following code to the success page:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params session_get_cookie_params();
setcookie(session_name(), ''time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
@session_destroy();
session_regenerate_id();
2) there should be a transaction ID binding on the bindings panel, this should be used in the update for the ID Value.
3) you would need to add an update behavior to the IPN Page for this and add a loop so that it updates for each item in the cart.
This will require custom coding to accomplish and will go beyond what we can offer support for through this forum, I would suggest signing up for a premiere ticket where we could help with this, we would also be able to fix the status issue in the premiere ticket pretty quickly.
4) the email receipt should also be sent from the IPN page, but you can display the items orders by adding a cart display manager to the page.
Steve E
Hi Jason
Thanks very much for getting back to me, I have not had a chance to take a look at it properly, but it all looks promising, I will let you know how I get on.
Steve E
Hi Jason
Thanks for the advice,
This is an example of what comes back from PayPal
ipn.php?tx=02E02861F2075391R&st=Completed&amt=0.04&cc=GBP&cm=13&item_number=
1/Works but I still have to get the user to login again?
2/The transaction ID binding is a long string 'Transaction ID: 02E02861F2075391R' not the orderID, I added a custom field to the PayPal form on the confirmation page and associated the OrderID with this, I then added the update recordset behaviour to the ipn page and post the transaction_status message to the dB (PayPal return value cm=13 cm is custom)
Which works fine.
3/I will probably raise a ticket on this. I take it there are no examples of the looping record set update record which I can look at?
4/I have the order details displaying on the order_success page, thanks for the tip, I also have got an email coming from the ipn page as a confirmation email, however it goes to only the cc and bcc, not to the recipient, also several items do not display, I get the qty, name & price no other details show in the email body, no image etc, I have tried sending it to a record set UserRS1 and to a session variable which I created for the user email. and I'm still having no joy. I have added an attachment containing the relevant files.
If you could take a look and let me know what's up I would really appreciate it. If you feel you could resolve both 3 and 4 on one ticket I will raise a ticket directly, both are basically related to the same pages?
Thanks in advance
1) See this thread for an example of maintaining the login;
showpost.php?p=80313&postcount=2
2 - 4) all of these issues are related to the same basic problem.
If you start a premiere ticket, we can work with you to correct them all rather quickly.
Steve E
Hi Jason
1/I have opened a premier support ticket, at least I think I have, it did not prompt for payment, could this be because I have recently purchace the upgrades for Data Bridge & Design Extender? I can not see it in my Support History yet?
2/The Session code I'm using is
@session_start('SecurityAssist_UserID');
//store user sessions - create a application variable for each user session variable from the login page
$UserID = $_SESSION['SecurityAssist_UserID'];
$UserFirstName = $_SESSION['UserFirstName'];
$UserLastName = $_SESSION['UserLastName'];
$UserLevel = $_SESSION['UserLevel'];
$UserEmail = $_SESSION['UserEmail'];
//add more application variables if you need to
$params = session_get_cookie_params();
@setcookie(session_name(), '', time() - 42000,
session_destroy();
@session_regenerate_id();
//restore the users session variables
$_SESSION['SecurityAssist_UserID'] = $UserID;
$_SESSION['UserFirstName'] = $UserFirstName;
$_SESSION['UserLastName'] = $UserLastName;
$_SESSION['UserLevel'] = $UserLevel;
$_SESSION['UserEmail'] = $UserEmail;
I'm still being prompted to login after the success page.
Thanks in advance
the sales department will be in contact wit you to schedule the appointment and make payment.
this section of code:
session_destroy();
needs to be changed to:
session_destroy();
Steve E
Sorry Jason
I must of updated this while you wrote the reply, as my code is pretty similar to yours but with the added UserEmail session variable, and it still prompts me to login again.
Sorry for the confusion.
try adding @session_Start(); just before the code to reset the session variables.
if this is still not working, there must be a session that login is looking for that is being missed.
Steve E
Hi Jason
Well all the eCart session variables would still be active at this piont because I have the cart display manager on the page, could this be the reason? should I add all the eCart session variables to be destroyed?
Here is the code I have at the moment
@session_start();
$SecurityAssist_UserID = $_SESSION['SecurityAssist_UserID'];
$_SESSION = array('$SecurityAssist_UserID, $UserFirstName, $UserLastName,$UserLevel, $UserEmail');
session_destroy();
$_SESSION['SecurityAssist_UserID'] = $SecurityAssist_UserID;
