ReferenceError
Thread begun 5/08/2012 9:25 pm by prawdzik.joseph438910 | Last modified 5/09/2012 6:23 pm by prawdzik.joseph438910 | 2136 views | 3 replies |
ReferenceError
I am experiencing the following error:
ReferenceError: WA_localURLToFilePath is not defined.
The error occurs when trying to use CSS Sculptor.
On my first installation I installed Data Bridge, Design Extender, and eCart all at once and then received this error. I then uninstalled all of the extensions and installed them one by one. First Design Extender. It worked fine. Then Data Bridge. It worked fine. Once I installed eCart I received the error. After uninstalling just eCart I still get this error.
It should be noted that after each installation I deleted the .dat file.
dvan_zelst
As far as i know the correct order should be:
1. E-Cart 5.04
2. Design Extender 1.05 (*new)
3. Data Bridge 1.01 (*new)
Try it in this order to see if it works.
the install order suggested by dvan_zelst is the correct order to use.
That worked! I am now error free! Thank you!!!
