Powerstore and Paypal Issues
Thread begun 5/08/2012 5:49 pm by kristina429176 | Last modified 5/10/2012 1:47 pm by Jason Byrnes | 2189 views | 3 replies |
kristina429176
I have set up a previous store with a payment gateway using credit cards and authorize.net. I am now trying to get a new estore working with paypal and my store keeps looking for an SSL or secure site to process after I click the checkout button. I have confirmed with paypal and they can see the process and can get it to go through, and I have spoken to my hosting technical site and they have said it is a problem in one of the customization scripts that is causing the issue. I really would like to get this site up and working for my customer. The program should not be looking for a secure site since it is going to either PayPal Standard or Express. If you can tell me which script needs to be edited that would be nice. If you would like to test out the site here is the addres since it is behind the scenes at the moment (index.php). The website has another cart in place and once this one is correct it will be replacing that cart. For testing purposes use the contribution product and then select the SKAB Donation and use $1.00. THis is my tesing item for the cart.
It has been very frustrating when this is suppose to be up and running with little (major work). I had several issues witht the first cart, but they did get resolved. This customer is very ansy because I need to get tickets up to sell and the cart is stuck. Please help.
since you are using paypal standard, SSL is not nesacarry
edit the webassist/plugins/shopping_cart/checkout_form.php page and change:
if (empty($_SERVER['HTTPS']) || $_SERVER['HTTPS']=="off") {
  if (!isset($_SERVER['REQUEST_URI'])) $_SERVER['REQUEST_URI'] = $_SERVER['PHP_SELF'];
  $testRedirect = "https://".$_SERVER['SERVER_NAME'].$_SERVER['REQUEST_URI'];
  $c = curl_init();
  curl_setopt($c, CURLOPT_URL, $testRedirect);
  curl_setopt($c, CURLOPT_TIMEOUT, 90);
  curl_setopt($c, CURLOPT_SSL_VERIFYPEER, 1);
  curl_setopt($c, CURLOPT_SSL_VERIFYHOST, 1);
  $result = curl_exec($c);
  if ($result)  {
      header("location: ".$testRedirect);
      die();
/*if (empty($_SERVER['HTTPS']) || $_SERVER['HTTPS']=="off") {
  $c = curl_init();
  if ($result)  {
      die();
kristina429176
Now Paypal Express instead of pyapal standard - probelms
Jason, that worked. Except I worked with one of your techniciams today and he reccomended I go to PayPal Express instead. I changed it to paypal express and now the paypal button when selected keeps going back to the same cart page. I have all the correct API codes in and I turned off the IPN for the paypal standard on my paypal account and now it does not go anywhere. ANy ideas how to fix quickly?
in the webassisxt/plugins/shopping_cart/pp_expessform.php file, change:
if (isset($_POST['PayPal_ExpressCheckout_button']))  {
if (isset($_GET['ExpressCheckout']) || ($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST))  {
