Search Not Working
Thread begun 5/08/2012 8:12 am by J7HNW | Last modified 5/10/2012 7:53 am by Jason Byrnes | 3263 views | 6 replies |
J7HNW
Search Not Working
Please can you help
I have run the database wizard and all pages work fine apart from Search ( Insert, Update etc all doing as they should )
If I search with no criteria - then the results all appear fine
One of the fields is TOWN
If I do a search by putting TOWN in the search and then enter HIGH for HIGH WYCOMBE which is a town in the database - the search returns nothing
Same if I search on any of the fields. However if I leave all the search fields blank - then all results are shown
Help please
please send a link where i can see the problem and a copy of the repvisits_Results.php page to troubleshoot.
J7HNW
Link
Hi Jason
Search file and Results file are attached
Link to search can be found here
repvisits_Search.php
John
to help troubleshoot add the following code to the results page, just after the <body> tag:
<?php echo("SQL: ".$query_limit_WADArepvisits); ?><br />
J7HNW
Code Added
Hi Jason
Code added just after Body tag
PHP:
J7HNW
Fixed
Hi Jason
In the end I ran the Wizard again and remade the pages and this time it has worked
Thanks for your help.
John
Ok, glad to hear it is working.
