Using DataBridge Insert Record with existing form
Thread begun 5/08/2012 7:50 am by YellowCircleWeb | Last modified 5/08/2012 8:43 am by Jason Byrnes | 2726 views | 5 replies |
YellowCircleWeb
I have a form that I created outside of DataBridge. I remember in the old versions of DataAssist you could use the insert record behaviour without having DataAssist create the pages for you - you could simply use your own pages. Is this still possible with DataBridge as I don't want to have to re-create my form all over again - I simply want to apply the insert record behaviour to my existing form
Ian S
Yes, you can use the standard Data Assist Insert / Update and delete behaviours as in the previous version.
Cheers
Ian
YellowCircleWeb
Thanks Ian, but do you know where I can find the insert/update options? I have looked in the DataBridge menus and the only options I can see in there overwrite my existing page with junk CSS from Formbuilder
in the server behaviors panel, click the plus button, then look under WebAssist -> DataAssist
YellowCircleWeb
Thanks Jason - I swear I'm going mad - I could have sworn I'd already looked there as I remember it being there in DA2. Found it now, right where you said it would be.
No Worries.
on the lighter side----
One of my favorite quotes from Salvador Dali:
"The only difference between myself and a madman is that I'm not mad."
