sCart Object - Discount value from recordset value
Thread begun 5/07/2012 4:39 pm by Lee Firth | Last modified 5/08/2012 1:25 pm by Lee Firth | 1992 views | 2 replies |
Lee Firth
Each client in the system I am working on has a discount value applied to them which is stored in a field in the client database (pm1_users.UserDiscount). The value is stored as an integer and is the percentage discount they are entitled to. How would I apply this discount using the eCart object?
in the authenticate use server behavior, go to the sessions tab and set the UserDiscount column to be saved to a session on login.
then in the eCart object, edit the discount, and add a trigger to the rule:
Session Variable 'UserDiscount' exists
and set the calculation as:
Based on cart subtotal:
Cart subtotal 'times' '$_SESSION['UserDiscount']'
Lee Firth
Thanks Jason.
