Slight Annoyances
Thread begun 5/07/2012 1:48 pm by bill173836 | Last modified 5/08/2012 12:05 pm by Jason Byrnes | 1080 views | 1 replies |
bill173836
Slight Annoyances
I think what you've accomplished here is great and love where you're going with this extension. Here are a few annoyances I've run into that I haven't seen listed.
1. Clicking the + button to create a page is sporadic. Sometimes the window opens and some times it take several clicks for a window to open. This is even worse when you click the + button to add fields.
2. I seems to me the Add all should be at the top instead of the bottom for a long list this is annoying especially if upon releasing it doesn't add anything. Which with a long list seemed to be 90% of the time.
3. Is there a way to prevent the page building from adding any css files to the page? I've taken all the styling used and made it one linked file.
4. How do you adjust the HTML Editor values before building the page. It looks like it just takes a default value.
5. If you add the Datepicker on build the link to the styles is broken.
1) This has been logged asa bug in our system to be corrected in a future update.
2) I have added a feature request for this.
3) No, you will need to remove the page css after the pages are created.
4) Only basic options can be configured for the HTML Editor instance on the Server Settings tab. Other settings will need to be changed after the pages are created by editing the instance on the page.
5) This is also a bug that has been logged to be corrected.
