Can an Admin Field be a link?
Thread begun 5/07/2012 10:49 am by elewis93815 | Last modified 6/01/2012 9:39 am by Jason Byrnes | 4363 views | 9 replies |
elewis93815
We have created an Admin area for our client to enter in new events for his theater. We would like one of the fields to be used to enter a link to a movie trailer. Is this possible?
Thank you,
Jackie
952.583.5616
the field in the database should be a standard varchar filed.
you can convert it to a link on the page that shows the information by adding the binding in the a tag, for example:
<a href="<?php echo($row_recordsetName['ColumnName']); ?>"><?php echo($row_recordsetName['ColumnName']); ?></a>
elewis93815
Hi Jason,
Thank you for your reply. I am a little confused. I have the field on the "Insert" page of the Admin area to be a standard varchar as directed. From here is where I am unsure of what to do next. When an event is entered into the insert page and I paste in a movie trailer url, it does not show the url in the results or details page, it is just blank. I understand that on the page that this information will show I should bind that field to the page, however, I'm not understanding how to get the link into the database via the Admin "insert" page. Any assistance is greatly appreciated!
Jackie
You should have a column in the database for the link text and a form field on the Insert page to enter the link.
you then need to edit the insert record behavior and bind the column in the database to the form element on the page.
then on the page that shows the link, you can add the column binding inside the a tag:
if you continue to have problems, send a copy of the pages.
elewis93815
Thanks Jason,
Still unsure of the direction. I'm getting stuck on the insert record behavior and exactly what to bind it to. I believe that I have added the column, made it a standard varchar, it shows on the insert page, however, how to get that field to be a link is troubling me.
I've attached the files. Please let me know if you need any other files to assist with this.
Thanks again,
Jackie
no files attached.
your getting ahead of yourself.
it is not a link going in to the database. on insert, it is only a web address:
http://www.mysite.com/page.php
it becomes a link when you get it out of the database and put it in the a tag:
elewis93815
Sorry, here are the files.
The data entered into this form field will be a link to a movie trailer. When we bind this form field to the the tickets.php page, it should be able to show a link to the movie trailer that was entered into the 'insert' page. Is this possible?
Here is a link also to a screen shot of the database columns.
No, the data entered into the form filed should only be the path, the URL to the movie trailer.
it will get converted to a link on the tickets.php
In the form filed, you should enter only the URL needed to get to the movie trailer:
http://www.site.com/movietrallerpage.php
then it gets converted to a link by using this code on the tickets.php page:
<a href="<?php echo $row_RSticketbooth['MOVIE_TRAILER']; ?>"><?php echo $row_RSticketbooth['MOVIE_TRAILER']; ?></a>
elewis93815
Hi Jason,
Where would I put the above code on the tickets.php page? Ultimately we would like the movie trailer to be show directly below the event description. I have attached the files, any assistance would be greatly appreciated.
to show the link bellow the description, you would put the link code bellow the event description
