DataAssist some more issues
Thread begun 5/05/2012 11:26 pm by dvan_zelst | Last modified 5/06/2012 3:28 am by dvan_zelst | 1731 views | 3 replies |
dvan_zelst
I'm not sure if these issues have been addressed yet but still want to point them out.
Hope a bug list will be posted soon as reference for everyone reporting bugs.
After creating pages with DataAssist i get errors as attached in below situations:
1. Selecting the 'Recordset WADA binding' from the bindings tab (img 006)
2. Selecting the 'delete record' server behavior in the server behavior tab (img 007)
Ian S
I don't want to state the obvious... but you do have a Testing Server configured in your Dreamweaver site setup?
Also, the second issue, i've seen this happen quite a lot over the years, mainly with the windows version of MySQL. Once i moved to a linux server the problem just magically went away.
Cheers
Ian
dvan_zelst
Hi Ian,
Yes everything is setup and working. I can select the normal recordsets without problem, this error only show if i select the delete record server behavior for some reason.
Did you try yourself?
dvan_zelst
Ok just reloaded the pages and tested again. Now it seems to work for some strange reason.
Next time i'll get this issue again i will post exactly what i did.
For now ignore this issue!
Thanks.
