Restarting Dreamweaver after upgrading Design Extender
Thread begun 5/05/2012 7:11 am by rmlee139451 | Last modified 5/07/2012 6:52 am by Jason Byrnes | 2670 views | 4 replies |
rmlee139451
After upgrading to Design Extender 1.04, whenever I start Dreamweaver, I get the following error:
The following JavaScript Error(s) occurred:
At line 12 of file "Macintosh HD: Users: rmlee: Library:Application Support: Adobe Dreamweaver CS5:en_us:configuration:Shared:WebAssist:LayoutManager:sharewd.js": wa is not defined
Any thoughts?
Steve E
I can not offer a solution but I am getting the same error on Windows
The following JavaScript error(s) occured:
At line 12 of the file "C:\Users\User Name\AppData|Roaming\Adobe\Dreamweaver CS5\Configuration\Shared\WebAssist\LayoutManager
\shared.js";
wa is not defined
Any suggestions would be apreciated, thanks in advance
MikeH
Hi
Not sure on the MAC but on windows that is the bug related to ecart. This was a known issue and can be rectified by installing the latest release of ecart (released to rectify that error).
Mike
Steve E
Thanks Mike
I noticed the update in the download centre, I had had Memento reminder turned off so I missed it, I did resolve it by uninstalling all the extensions, Removing Dreamweaver Preferences as detailed here..
restore-preferences-dreamweaver-cs4-cs5.html#main_Restore7V
I then purchaced Data Bridge, and updated E Cart 5 to 5.04, and restarted my system, then reinstalled the extensions as per the post ...
showthread.php?t=24005
Restarted my system again, started DW and activated the extensions, all is good now.
Well done WA with the Data Bridge Extension by the way, it certainly makes it easier to reinstall after the updates
I hope this helps.
This is an issue that we have recently discovered, it seems to happen with either eCart 5.0.3 or CSS Sculptor 3.0.2 installed.
we have recently released eCart 5.0.4 to correct the problem and will be releasing an update to CSS Sculptor as well.
This error is more of a nuisance and should not effect functionality if you ignore it.
