CSS Menu Writer Issue
Thread begun 5/05/2012 6:36 am by kwsim | Last modified 5/07/2012 11:26 am by Andrew Read | 1297 views | 2 replies |
kwsim
I only have Design Extender ver. 1.0.4 installed in the Extension Manager, have rebuilt the Configuration folder, deleted the Cache file and re-installed the extension. I created and saved a blank PHP page. Then I select WebAssist > CSS Menu Writer. I go to Define in the Theme section. When this section opens everything looks fine. However, if I select the "Item" tab under Dimensions, Margin & Padding all of the "px" disappears in the main window and all the drop downs in the "Item" tab are blank. I am unable to set the dimension type for the menu item.
I even tried to start with other pre-defined menus and themes, and tried to edit its theme and the same issue resides.
I spent an hour un-installing my individual extension and installing this extension. Then another two hours trying to get CSS Menu Writer to work. The YouTube Video states that I can make my money back by using this extension for a client. Well, I am not producing anything for my client and spent over three hours of my own time trying to get this extension to work. Now I have to spend the next two hours removing this extension and re-installing all my individual extensions just so I can get to work. Five hours of my time waisted. Good thing WA is not paying me for my time because this extention for me would be FREE. :mad:
This is an issue we just recently discovered with Design Extender, we will be releasing an update this week to correct the problem.
Andrew Read
Please add this to the sticky.. I didn't see this bug in there.
