Another Error
Thread begun 5/04/2012 2:49 pm by davidirvan2000437653 | Last modified 5/10/2012 9:24 am by adromidon | 6104 views | 9 replies |
Another Error
So after uninstalling the previous extension and upgrading I am having nothing but problems. Also, I don't know why Web Assist does not make this forum searchable or if it is make that more obvious. Anyways. When trying to use the CSS Menu I am getting the error:
WA_local_URLtoFilePath is not defined???
i ran into this with another customer and we renamed the users configuration folder, then reinstalled the extensions to correct the problem.
first make sure Dreamweaver and the Extension manager are closed.
for help locating the configuration folder, see the common installation issues PDF:
once you locate the configuration folder rename it.
then open the extension manager, remove the existing extensions, the reinstall. See this thread for install tips:
showthread.php?t=24005
This forum uses third party forum software from vBulletin, searching has always been a problem in vBulletin.
I sugest using google for more acurate search results.
you can use an advanced search to target only the forums in google by using the following in your search string;
site:forums
Not fixed
I renamed the configuration folder and uninstalled, and reinstalled my extensions. That actually fixed my other problem that I still have an open ticket for with all of the error messages popping up when I open dreamweaver. Also, it successfully deleted my workspace. Unfortunately it did not fix my problem mentioned above with the CSS Menu Writer.
We will be releasing an update to both Design Extender and to Data BRidge that should correct the issue you are reporting, the updates should be released with in the next couple of days, I'm hoping for the Data Bridge update to be released later today.
adromidon
I have followed the steps here and have the issues still. I am using Design Extender 1.0.6 and I still get the WA_localURLToFilePath is not defined error.
As mentioned I have renamed my old configuration folder and re-installed the extensions.
This error appears when trying to run CSS Sculptor for me.
The latest version I see for DE is 1.0.6. Is this the version that was supposed to fix this issue?
I figured since the gentleman that started this thread had the same issue i would post it here instead of starting a new thread .
yes, DE 1.0.6 should correct the problem.
the install order should be:
eCart 5.0.4
Data Bridge 1.0.2
adromidon
I currently only own the DE eCart 5 and a few alacart extensions (do not have the fund to upgrade to the integrated data bridge package yet)
So I usually install DE ala cart extentions (UE4, Datassist 2, Cookie Toolkit 3, sometimes Security assist 1 but have not installed it yet so not a factor in the error ) then do eCart 5. so your saying i should do Ecart first then DE then the other 4?
No, the other 4 should be installed first, then eCart followed by design extender last.
adromidon
Ok I will try that thanks
adromidon
That worked thank you very much
