Error message when DW is loading
Thread begun 5/04/2012 6:55 am by Ben Pleysier | Last modified 5/05/2012 12:33 am by Ben Pleysier | 1687 views | 2 replies |
Ben Pleysier
Although it does not cause a problem once I am in DW (Jagger), I get two error messages as per when loading DW attachments. The second image is the first error message.
we released eCart 5.0.4 a couple of days ago to correct the first error.
for the second error it sounds like you may have conflicting extensions installed.
see the following thread for extension install tips:
showthread.php?t=24005
Ben Pleysier
Thank you for your prompt reply.
I spent all day today removing each and every extension which ofcourse made things worse. Then removed the configuration folder and the associated Registry Entry, reinstalled all extensions include the new Data Bridge and am now very happy to announce, all is well.
Concurrently, this is a confirmation that all of the WA extensions work in Jagger (CS6)!
