unable to edit datepicker theme
Thread begun 5/04/2012 5:56 am by CraigR | Last modified 5/04/2012 10:33 am by Jason Byrnes | 1703 views | 3 replies |
CraigRBeta Tester
Just starting to get the hang if this extension.
I thought I would try creating a booking form with data insert and validation using the Datassist wizard.
The form was created successfully, as was the data insert, and the validation works too.
However when i try and edit the style of the datapicker, the changes are never saved and the original style is always retained.
I have logged this as a bug so it can be corrected in the update that will be released soon.
Thanks for reporting this.
dvan_zelst
Dear Jason,
Would it make sence to post a full bug list together with the upcoming fix release. This way everyone can check in this list if their reported bug/issue is in there and fixed.
Also this way everybody can test/debug once more these bugfixes to confirm it is working the way it should.
I will compile a list later today and post it.
