Memento Panel click to Crash DW6
Thread begun 5/03/2012 9:28 am by Peterson Design Studio - jefferis | Last modified 5/07/2012 6:23 am by Jason Byrnes | 2827 views | 1 replies |
Hi folks, I've an early copy of DW6 and just want to report a reproducible bug crash when you click on any item displayed to Open or get more info. It causes DW on Mac to crash:
Process: Dreamweaver [55639]
Path: /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/Dreamweaver
Identifier: com.adobe.dreamweaver-12.0
Version: 12.0.0.5806 (12.0.0)
Code Type: X86 (Native)
Parent Process: launchd [502]
Date/Time: 2012-05-03 12:19:56.758 -0400
OS Version: Mac OS X 10.7.3 (11D50)
Report Version: 9
Interval Since Last Report: 571127 sec
Crashes Since Last Report: 3
Per-App Interval Since Last Report: 95737 sec
Per-App Crashes Since Last Report: 2
Anonymous UUID: 3253AB4B-EB2C-472E-9E7B-A3C1E3953E84
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000006d614e65
VM Regions Near 0x6d614e65:
__LINKEDIT 00000000400cf000-000000004010b000 [ 240K] r--/rwx SM=COW /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
__TEXT 000000008feb6000-000000008fee9000 [ 204K] r-x/rwx SM=COW /usr/lib/dyld
Application Specific Information:
objc[55639]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.adobe.dreamweaver-12.0 0x01192071 DW_SftTree_RowDragCapture::DoMouseEvent(dvaui::ui::MouseEvent const&) + 193
1 com.adobe.dvaui.framework 0x0390fb51 dvaui::ui::UI_Node::UI_DispatchCapturedMouseEvent(dvaui::ui::MouseEvent const&) + 383
2 com.adobe.dvaui.framework 0x0390fd69 dvaui::ui::UI_Node::UI_DispatchMouseEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&, bool) + 113
3 com.adobe.dvaui.framework 0x0390fe26 dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent const&, bool) + 68
4 com.adobe.dvaui.framework 0x0397e01b dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 1095
5 com.adobe.dvaui.framework 0x0397bc6c dvaui::ui::OS_View::UI_DispatchPlatformMouseMoveEvent(dvaui::ui::OS_Event const&, bool, bool) + 298
6 com.adobe.dvaui.framework 0x0397ad37 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 413
7 com.adobe.dvaui.framework 0x0397c217 dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 29
8 com.adobe.dvaui.framework 0x03978b5b dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 77
9 com.adobe.dreamweaver-12.0 0x011b07ff boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, dvaui::ui::OS_View, NSEvent*>, boost::_bi::list2<boost::_bi::value<dvaui::ui::OS_View*>, boost::_bi::value<NSEvent*> > >, void>::invoke(boost::detail::function::function_buffer&) + 47
10 com.adobe.dvacore.framework 0x033e21fa int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 36
11 com.adobe.dvacore.framework 0x033e30f8 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(boost::function0<void>*, void*), boost::_bi::list2<boost::_bi::value<boost::function0<void>*>, boost::_bi::value<void*> > >, int>::invoke(boost::detail::function::function_buffer&) + 24
12 com.adobe.dreamweaver-12.0 0x01139fe8 TestErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 50
13 com.adobe.dvacore.framework 0x033e20ef void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::function0<void>, bool*) + 135
14 com.adobe.dvacore.framework 0x033e4bb1 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 129
15 com.adobe.dvaui.framework 0x0396f3ac -[DVAMacContainerView mouseEntered:] + 156
16 com.apple.AppKit 0x9a9fee26 -[NSTrackingArea _mouseEntered:] + 63
17 com.apple.AppKit 0x9a9999d7 -[NSApplication sendEvent:] + 7076
18 com.adobe.dvaui.framework 0x03969ac4 -[DVAMacApplication sendEvent:] + 852
19 com.adobe.exo.framework 0x040ca77f -[ExoMacApplication sendEvent:] + 559
20 com.apple.AppKit 0x9a92a6d5 -[NSApplication run] + 1007
21 com.adobe.exo.framework 0x040c9bd3 exo::app::OS_AppBase::RunEventLoop() + 67
22 com.adobe.dreamweaver-12.0 0x01138455 CRealApp::Run() + 395
23 com.adobe.dreamweaver-12.0 0x0111bdc0 CWinAppImpl::Run() + 36
24 com.adobe.dreamweaver-12.0 0x0111c0af main + 95
25 com.adobe.dreamweaver-12.0 0x004dcff5 start + 53
thank you for reporting this, we will be evaluating CS6 compatibility once CS6 is released and will look into the necessary updates at that time.
