UE3 Multiple field in body
Thread begun 5/03/2012 8:31 am by mistersmith307820 | Last modified 6/21/2012 1:37 pm by mistersmith307820 | 3397 views | 8 replies |
mistersmith307820
I am adding another text field to an existing contact form. The site owner wants a phone number field to be sent. I have added the input field here on my testing server, but now need to edit the wizard.
Under the body tab on the editor, in the edit mode I want to post "Phone".
My current code looks like this:
<?php echo ((isset($_POST["Subject"]))?$_POST["Subject"]:"")?>
should the new code look like this?
<?php echo ((isset($_POST["Phone"]))?$_POST["Phone"]:"")?>
As a side question, what code is added so that when a visitor clicks in a text field the initial value disappears so they can input their own without having to erase first?
thanks!!
the page in question can be located at laumont dot com/Info/submit-a-query.php
Assuming that the name of the form element in question is named "Phone", then the new code is correct.
you could clear the default value using a javascript onFocus event, for example, change:
<input name="Name" type="text" id="Name" value="Your Name" size="30" maxlength="50" />
<input name="Name" type="text" id="Name" value="Your Name" size="30" maxlength="50" onFocus="if(this.value == 'Your Name') this.value='';"/>
mistersmith307820
I changed the code to what I have listed above and I get a javascript error (see picture)
mistersmith307820
Am I able to change the setting right in the code? WAUE_pagename.php in the WA_Universal_Email folder?
add to the section
//Start Mail Body
$MailBody = $MailBody . "";
$MailBody = $MailBody . ((isset($_POST["Subject"]))?$_POST["Subject"]:"");
//End Mail Body
perhaps?
yes, you could change:
//Start Mail Body
//End Mail Body
//Start Mail Body
$MailBody = $MailBody . "Subject: ";
$MailBody = $MailBody . "Phone: ";
$MailBody = $MailBody . ((isset($_POST["Phone"]))?$_POST["Phone"]:"");
//End Mail Body
mistersmith307820
Awesome and thanks!
Both solutions worked, onfocus and $_post.
Thanks a million Jason
mistersmith307820
Each form entry on a new line
I have incorporated this into another site, but this one has more fields to be in the body of the email.
How would I get each form field to be on a new line of the email instead of one long string?
this is how I have it now
//Start Mail Body
$MailBody = $MailBody . "Name: ";
$MailBody = $MailBody . ((isset($_POST["Name"]))?$_POST["Name"]:"");
$MailBody = $MailBody . "Email: ";
$MailBody = $MailBody . ((isset($_POST["Email"]))?$_POST["Email"]:"");
$MailBody = $MailBody . "Message: ";
//End Mail Body
add \r\n for line breaks:
//Start Mail Body
$MailBody = $MailBody . "\r\n";
//End Mail Body
or use <br> tags:
//Start Mail Body
$MailBody = $MailBody . "<br>";
//End Mail Body
mistersmith307820
great!
<br>
did the trick!
