Errors on dreamweaver open
Thread begun 5/03/2012 8:22 am by Jedi | Last modified 5/07/2012 9:10 am by Jason Byrnes | 5198 views | 8 replies |
Jedi
I have read the other errors and fixes and I have uninstalled html editor3.02, security assist, validation toolkit, ecart 5.03, cookies toolkit, dataAssist 2.
I then reinstalled ecart 5.04 first and then installed DataBridge 1.0 and I still get the following errors on dreamweaver startup:
Unable to open script file "C:\xxx\Adobe\Adobe Dreamweaver CS5.5\Configuration\Shared\WebAssist\Preferences\RSSUpdate.js"(error3).
also get error At line 12 of file "C:\xxx\Adobe\Adobe Dreamweaver CS5.5\Configuration\Shared\WebAssist\LayoutManager\shared.js":
wa is not defined
also get Unable to find file WA_Memento.htm in the Configuration/Floaters directory. The floater will not be shown.
Help would be appreciated.
in Dreamweaver, reset the workspace layout by going to Window -> Workspace Layouts -> Reset '<Your Layout Name>'
then close Dreamweaver and Delete the Dreamweaver Cache file from the users configuration folder:
Jedi
thanks Jason,
I did that and the other errors went away but the folowing error still pops up on loading dreamweaver css5.5
error At line 12 of file "C:\xxx\Adobe\Adobe Dreamweaver CS5.5\Configuration\Shared\WebAssist\LayoutManager \shared.js":
wa is not defined
Miguel
Same here reseted layout and deleted cache file still getting that javascript msg when opening dreamweaver this began since this new extension
CraigRBeta Tester
same
Isn't this the same error as this thread ?
showthread.php?t=26159
Yes it is, we corrected the issue in a connect session by renaming the users configuration folder and reinstalling eCart 5.0.4 , then data bridge.
Jedi
The only way I could fix the error "error At line 12 of file "C:\xxx\Adobe\Adobe Dreamweaver CS5.5\Configuration\Shared\WebAssist\LayoutManager \shared.js":
wa is not defined"
was to do as you stated with the addition of deleting Eric Meyers CSS Sculptor extension. Once this extension was removed then dreamweaver CSS 5.5 opened with no issues.
I have logged this issue as happening with CSS Sculptor as well. we will be releasing an update to CSS Sculptor to corrrect the problem.
In reality, this is more of a nuisance error, and will not effect functionality if you ignore it.
