Layout Manager Error
Thread begun 5/03/2012 2:54 am by sinan | Last modified 5/03/2012 4:37 am by John Langer | 1558 views | 3 replies |
sinan
I have Layout Manager error. I deleted cache file in my folder
C:\Users\user\AppData\Roaming\Adobe\Dreamweaver CS5.5\en_US\Configuration
when I open Dreamweaver I am getting error message.
John LangerBeta Tester
This is a known bug that is caused by having eCart installed. WA are bringing out a fix for eCart next week which will cure it by making it compatible with DataBridge. In the meantime you can safely ignore the error message. It has no known consequence.
Ian S
Hi John,
The fix is out already in the download centre and it does indeed make the error go away.
Cheers
Ian
Originally Said By: Ian S
  Hi John,
Cheers
Ian
Thanks Ian, hadn't realised that.
