How to produce just a registration page.
Thread begun 5/02/2012 7:12 pm by h150477 | Last modified 5/04/2012 9:37 am by h150477 | 2259 views | 4 replies |
h150477
The wizard produces all the pages at one go. If you try to run it again to correct an error on one page, it ruins all the other pages by writing two sets of code on the pages which duplicates the forms. Which is a pain if you have done any modifications to them.
Possible workaround?
1. Rename the pages that you wish to save.
2. Run the wizard again.
3. Delete the new pages that you do not need.
4. Revert back to the original names.
5. Relocate the files to a suitable location.
Has anyone found a way to tell SA where to store its files other than in the root directory of the site?
in the security assist wizard (Webassist -> Security Assist -> Create Security Pages, go to the Manage Pages tab.
in the listing of pages to create, select the pages you don't want to create and click the trash Can (Delete) icon.
to foce security assist to create the pages in another directory, add the path to the name of the page. for example select the registration page, the file name will be set to:
registration.php
you can add he path in front of that where the page should be created:
my/path/registration.php
h150477
The trash can on the manage pages screen is always greyed out .
I can create any combination of login page and every other page, but the login page is always produced, so the solution seems to be to create the final logon page last.
To solve the problem, I created 4 different presets, all with login and one other file, and another with just the login page.
As to creating pages in another directory that only works if you type the path into the Page Location field, but when you save the preset, next time you run it it changes the path to Root relative instead of page relative. It works it out wrongly and posts the pages in the htdocs folder instead of the site folder.
Consequently the pages cannot find the server resulting in many error messages and lots of head scratching before I did a search to find the files.
The browse for file does not work in my windows 7 64 bit system. It finds the folder and then says "no items match your search. " Which is quite logical as the file does not exist! If you type the file name into the browser it then advises that the file should be saved first, but it does create a tempoary path and saves the file in the correct location.
So its still a problem if you need to recreate the files.
And tricky to get them into the correct directory.
h150477
screen shot showing the what pages screen, showing the greyed out trash can and the file location anomoly
h150477
After lots of thought I got the registration page to work - it only took me about 6 weeks on and off. It needs a higher degree of logic and more careful study of the notes and instructions than I had been using.
The main problem was that in the past when inserting records into a database, I had always had the user_id (or index to the table) on the form as a hidden field, or the DW server behaviour did not work. Only after seeing a brief note about not using key fields in registration pages somewhere in the help did it finally click.
So this post is not really needed - but I have learned a lot from posting it and receiving Jason's answers.
Thanks a lot Jason.
Now I have to test the user update and lost password forms.
I'll probably be back.
