Stopping 3rd party extension working.
Thread begun 5/01/2012 12:11 pm by MikeH | Last modified 5/02/2012 7:22 pm by dvan_zelst | 6127 views | 16 replies |
MikeH
Hi
I know this was solved in the past but since installing DB it has now stopped DmXzone extensions behaviour connector working again.
This used to be down to client side validation and was working with no issues with DE installed. It seems Db has now created the issue again.
Any ideas on what needs to be done to stop this?
Mike
dvan_zelst
I looked back posts on DMXZone and at the time this problem existed it was related to:
WA - FormToolKit.
See: "Go inside the Configuration/Behaviors/Actions folder and move the Validation Toolkit folder out and up one level. See if that resolves the crash. It did for me."
I'm not sure if this time it is the same issue, some also mentioned Security Assist was the problem but i'm not sure if Form Toolkit is part of SA.
MikeH
Hi
Unfortunatly this time as all extensions are combined that folder doesnt seem to exsist and due to the intergration what will happen if you disable something.
Mike
dvan_zelst
I agree with you, also i just upgraded to this new extension and have not tried it out yet.
I just pointed out how it was that time so maybe WA developers can have their benefit from it to find the reason causing this issue again.
I hope they will as i'm using a lot of this 3th party extensions myself.
Will post my findings once tested myself.
MikeH
It would be instersting to know if you have the same as this is a bit of a show stopper for me. I use both companies extensions and would like to see a permanent fix for this one.
Mike
dvan_zelst
I will try it tonight and post my results. If i have the same issue then it will be bad for me as well but i'm sure a solution from either site will be found then.
MikeH
I would think so WA usually find a way to sort issues out.
Mike
dvan_zelst
Ok, here is the deal!
WA, i can report the same issue with the DMXZONE behavior connector.
Once the WA extensions (ECart,Extender,Bride) are installed, Dreamweaver crashes when trying to open the Behavior connector from DMXZONE extensions.
Please make sure to fix this issue with the upcoming release as well!!!
Thanks.
MikeH
Hi
At least its not just me, hopefully that should make it easier to track.
Ray, Im on Skype today if you fancy have a go at looking at this issue.
Mike
dvan_zelst
Nope it is not just you! Also i have a feeling it is the same issue as before, maybe even the same extension as mentioned in my earlier post. However it might be somewhere else located, as you mentioned the extensions are now combined into one.
