Problems with Search parameter
Thread begun 5/01/2012 11:07 am by sandy170299 | Last modified 5/08/2012 10:19 am by Ray Borduin | 2724 views | 4 replies |
sandy170299
This site (donationSearch.cfm) is not working properly when search is submitted. I am receiving the following error: [Macromedia][SQLServer JDBC Driver][SQLServer]Line 5: Incorrect syntax near ')'.
Do you need a copy of the file?
yes, please send a copy of the search page.
sandy170299
Jason, can you open a support ticket? The page may contain some data I don't want visible. Thank you!
This was an issue with your "Reconciled" dropdown list. The first option "--choose an option --" needs to have a blank value specified or else it will actually use the text to search the field and in this case it was a numeric field, causing the error.
To fix the problem I updated:
<option>-- choose an option --</option>
<option value="">-- choose an option --</option>
