Help does not work
Thread begun 5/01/2012 12:36 am by neo314 | Last modified 5/03/2012 1:54 pm by Matthew Meling | 2994 views | 7 replies |
neo314
Help does not work
The help link on the database pages wizard sends me to:
file:///C|/Users/[user]/AppData/Roaming/Adobe/Dreamweaver%20CS5.5/en_US/Configuration/Shared/WebAssist/RichTextEditor/Help/index.htm#wa_qb_13.htm%3E%3Ecap=HTML%20Editor%20-%20Help%20Documentation%3E%3Epan=2%3E%3Epbs=toc|ndx|nls%3E%3Epdb=toc
which is a broken link. I replaced my computer user name with [user], but that value was correct.
Matthew Meling
Hey there Neo,
There seems to be an issue with the help buttons in DataAssist, so until the issue is resolved, you can view the online help for DataAssist by going to index.html
dvan_zelst
Is this help file related to the new DataAssist3 (in DataBridge) or DataAssist2 (Stand alone version)?
This is the help for DataAssist 3 from Data Bridge. We have identified the issue with the in-product help links and will be addressing them for an update likely available early next week.
dvan_zelst
Hi Ray,
Thanks. I must say i do like what i read in this document for DataAssist 3.
I also read somewhere that templates/themes are added to the DA pages after creation correct?
Good job.
Templates/themes are not added by the wizard but can be added after creation, or the pages can be used as plugins on existing pages with or without templates and themes.
This is really a job for our Framework Builder functionality and is kept separate from the wizard.
superpac250441
I have been going through the DA3 help section of this AWESOME extension. Would it be possible to obtain a pdf version once the dust has settled?
Matthew Meling
Hey there SuperPAC,
Unfortunately, we don't create PDFs of our help any longer, but you can print the help if you need a hard copy of it.
