Current Presets
Thread begun 4/30/2012 5:25 pm by Gary Young | Last modified 4/30/2012 5:32 pm by Gary Young | 1031 views | 2 replies |
Gary Young
Current Presets
I just purchased Data Bridge, but before installing I was wondering about all the presets I have defined in the original extensions. I have dozens of Form Builder presets along with Button Styler, Validation Tool Tip styles and SA registration definitions. Will these presets import natively (does Data bridge know to look forthem) or do they all need to be exported prior to current extensions removal and, if so, can they be imported to Data Bridge?
Regards,
Gary
you will need to export them from the preset manager by going to WebAssist -> Preset manager.
in the preset manager, select each preset to export, then click the export button.
after installing database bridge, open the preset manager and use the import feature to import them.
you will need to first select the correct preset type, then click the import button to import them.
Gary Young
Thanks for the quick response Jason!
