issue of email placement in code
Thread begun 4/30/2012 1:05 pm by Christopher West | Last modified 5/02/2012 9:47 am by Jason Byrnes | 2642 views | 5 replies |
Hello.
I got a page that on update sends an email to a customer to tell them of their order progress. I had to place the email code inside the repeat region though since it was the only way to link the customer email with the email "TO" email reference in the email server behaviour - this all works...except then email is ONLY sent out on the "next page update" and then it only sends out the previous email and not the current email that the admin is clicking to update (if that at all makes any sense to how I wrote it :)
attaching code to see if you can help :)
Chris
1) the email code should not be in the repeat region, it should be left before the doctype tag.
2) In the Universal Email wizard, click the To button to set the to address to use a recordset loop.
3) The order of the code will need to be changed slightly. right now, the code for the rsOpenOrders recordset is before the update record code block, you will need to rearrange this so it is after the update record code block, but before the Universal email code block.
the code order should be:
update record
Universal Email
thank you :) perfect its sorted :) i just need to amend it slightly now as the last process in the update is "shipped" but i have coded it so that when the record gets updated to "shipped" it gets removed from the open-orders page and gets displayed in the closed-orders page but for some reason the email doesnt get sent to the customer to say its shipped - so im assumning that the update happens, the record disappears so there is nothing for the universal email behaviour to send. hmmmm :-\
well, the recordset your are using for the email is:
SELECT * FROM orders WHERE OrderStatus = 1 AND OrderProcess != 'Shipped'"
you would need to use a diferant recordset for sending the email:
another issue im having with this page - im getting the emails but for some reason its sending duplicate emails (I think its sending a 1 duplicate email to the amount of how many records are on the page - so for example I have 6 customer records and its sending the same email 6 times to the same customer email address). here is the page in question.
I hope its a simple fix :)
Chris
in the To Address settings screen, try increasing the Wait setting. some SMTP servers send duplicate emails if too many are sent at a time.
