Admin pages re direct incorrectly
Thread begun 4/30/2012 7:31 am by elewis93815 | Last modified 4/30/2012 2:10 pm by Jason Byrnes | 2639 views | 5 replies |
elewis93815
Hello,
We have built a DataAssist Admin area for our client to enter new events coming to his theater. When we attempt to enter a new event, a couple of things are happening.
1. The end date is not showing up
2. When we hit "insert" the page is directed to a page I do not recognize. ticketbooth_Detail.php My thought is that it should be directing to the ticket_booth_Detail.php page. This same problem is happening when you attempt to update an already listed event.
Also, is there a way to have the "Poster" field be a browse for image field so that the poster can be chosen and then upload right from the Admin Insert Page?
Thanks!
Jackie
1) To help troubleshoot, edit the following line:
$WA_redirectURL = "ticketbooth_Detail.php";
$WA_redirectURL = "";
to prevent the redirect, then add the following code just after the <body> tag to write the insert query to the screen:
<?php echo("SQL: ".$WA_Sql); ?>
post this back in your reply.
2) There is a know issue for this in the data assist download center page.
3) Yes, you could use remove the poster text field and replace it with a file filed of the same name, then use the File Manipulation -> Upload file behavior. see the data assist support page for a tutorial on adding digital file pro to data assist insert and update pages.
elewis93815
This is the error message I get when I added the script
Hi Jason,
This is what we get after we've added the code you listed in the previous post:
- Jackie
SQL: INSERT INTO `ticketbooth` (`POSTER`,`EVENT`,`EVENT_DESCRIPTION`,`PURCHASE_TICKETS`,`START_DATE`,`TIME`,`END_DATE`,`PRICE`,`MINIMUM_AGE`,`KID_FRIENDLY`,`NON_SMOKING`,`WHEELCHAIR_ACCESSIBLE`,`SEATING`,`TICKETS_AVAILABLE`) VALUES ('','','','',NULL,'',NULL,'','','','','','','')
is this after submitting a new event?
this doesnt look like it is passing any information into the table.
elewis93815
Yes, this is the message I get at the top of the screen when I hit insert.
