URL parameters and Ampersands
Thread begun 7/29/2009 2:11 pm by ccooper309155 | Last modified 7/29/2009 5:10 pm by ccooper309155 | 5764 views | 5 replies |
ccooper309155
Hi
Using ASP VB.
I need to send some railroad names to another page via URL parameter.
A name like Southern Pacific works:
e.g. railroad_prod_list.asp?Road=Southern%20Pacific
But a name such as Baltimore & Ohio doesn't work because of the ampersand.
e.g. railroad_prod_list.asp?Road=Baltimore%20&%20Ohio
The ampersand confuses things because it means something different to the server and browser.
How can I work around this?
And no, I can't change the railroad names!
Craig
Justin Nemeth
try using Server.URLEncode() around your railroad names. That should convert the & to a url friendly character.
ccooper309155
Originally Said By: Justin Nemeth
Thanks.
Will give it a try and let you know how it goes.
Does it matter that the railroad names are generated dynamically on the sending page?
Justin Nemeth
No, that function can accept any string - so a field from the database could just be wrapped in that function.
ccooper309155
Okay, I'm a dope.
Here is my link:
<a href="railroad_list.asp?RailRoad=<%=(rs_Railroad.Fields.Item("RailRoad").Value)%>"><%=(rs_Railroad.Fields.Item("RailRoad").Value)%></a>
How/where exactly do I apply the Server.URLEncode() to this code?
Everything I tried didn't work.
Thanks!
ccooper309155
I solved it:
<a href="railroad_list.asp?RailRoad=<%=(Server.URLEncode((rs_Railroad.F ields.Item("RailRoad").Value)))%>"><%=(rs_Railroad.F ields.Item("RailRoad").Value)%></a>
