How to redirect users to previous page using SESSION and/or COOKIES
Thread begun 4/27/2012 3:17 pm by danny405167 | Last modified 4/30/2012 6:42 am by Jason Byrnes | 6362 views | 1 replies |
danny405167
Is there a solution recipe for the following:
User logins from main page -> user is redirected to user profile page
if user logins from shop.php page -> users is redirected to previous page
Below is a pieceof code that I found on this forum and works perfect for redirecting users based on their user level. Now I would like to make it redirect to previous page when users do not log in from main page.
if(!session_id()) session_start();
switch($_SESSION['userLevel']) {
case "1":
header("Location: admin_index.php");
break;
case "2":
header("Location: clients_index.php");
break;
The problem that I have is
1) Can the above code have an else if statement to add the third scenario? If so, can you please tell what is wrong with the code below.
case "1":
break;
case "2":
break;
else if(!session_id()) session_start();
switch($_SESSION['userLevel']=9) {
case "3":
2) How do I add a SESSION to shop.php page so that Security Assist knows to redirect the user to the previous page and not the control page. I found and added the following code to the shop.php page but no luck. Does Security Assist has a function to add the SESSION to the page or I will have to hand code it allays?
if(!isset($_SESSION["userLevel"])) {
$_SESSION["userLevel"] = "9";
1) This code uses the switch case concept. You cannot add an else statement to the switch .. case.
think of it as a switchboard.
the switch statement sets a variable to be used for comparison. the case statement sets an action to be performed if the comparison variables matches the case value.
the code:
    case "1":
        break;
    case "2":
        break;
could also be written using if... else, but switch... case is more efficient:
if($_SESSION['userLevel'] == "1") {
} elseif(
$_SESSION['userLevel'] == "2") {
to add a third scenario to the switch... case code, you just need to add another case statement:
    case "1":
        break;
    case "2":
        break;
    case "3":
        break;
2) Redirecting back to the previous page is not done using a session variable. when you access a proteced page, it redirects to the login page with a querystring varaible that contains the path to the protected page named "accesscheck":
users_login.php?accesscheck=%2Fsculptortocms%2Fadmin_cms%2Findex.php%3F
just make sure that the action of the login form on the login page is set to pass any existing querystreing variables by using this code for the action attribute:
 action="<?php echo htmlspecialchars($_SERVER["PHP_SELF"]); ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlspecialchars($_SERVER["QUERY_STRING"]):""?>"
