Repeat Region Update not working
Thread begun 4/27/2012 12:04 am by Christopher West | Last modified 4/27/2012 7:47 am by Jason Byrnes | 1616 views | 1 replies |
This is odd, as Im sure it was working a while ago (but somehow I think an old file got saved to my may project folder). I have a page with a repeat region on all "product orders" each record is inside a form with a "save" button so that the admin can simply chose from a drop down what order status an order is at.
I have tried different combinations of using an update in terms of positioning code. But for some reason it just doesnt work how I was hoping it would (I managed to get the very first record to update in the database but all other records within the repeat region dont update. I have attached the crafty file in question..any thoughts on my mistake?
Chris
the problem is in the update behavior, you set the key column to the order ID column (This is correct) but here are the 2 mistakes you have made:
1) You have set the key Value to use the rsOpenOrders.OrderID column
2) On the update page, you have again bond the orderID column to the rsOpenOrders.OrderID
for one, when the update is executed, it does not loop through the recordset, this is why only the first record is ever updated, the recordset never moves to another record to update any others.
for two, you dont want to update the ID value only the status value
in your form, add a hidden form element for the order ID and bind it to the rsOpenOrders.OrderID column.
In the insert behavior, set the Key value to use the hidden element. on the update page, do not bind the orderID column to anything so it wont be updated.
