Filter Search (just like on webassist products page)
Thread begun 4/26/2012 9:48 am by Christopher West | Last modified 5/02/2012 4:41 pm by Christopher West | 6551 views | 14 replies |
Hi there, Im trying to get the same effect as on your page: dreamweaver-extensions/
where upon I can filter products using a select box and sort products using a select box - but been unsuccessful. What is the correct workflow to do both? as they dont use a button event so im assumning their using a onclick event.
would it be a simple case of using dataassist search and sort server behaviours and then just create a couple of select lists with onclick triggers?
Chris
The extensions page just uses a standard data assist search and sort behavior there is a separate form for the filter and the sort select lists, and they are set to submit the form on change using javascript:
onChange="document.formName.submit();"
first get the search working with a standard form using a submit button, then add the onchange event to the select list to submit the form with out the submit button.
do the same for the sorting.
Hi Jason, I got the sort and the search working on the page. but i cannot seem to get the search working without a button and same with the sort function.
The code I was using for the drop down menu was as follows:
<form method="post" name="sortform">
<select name="sortfield" id="select" onChange="document.sortfield.submit();">
<option value="../../account.php?page=manageproducts&sort=ProductPrice">Price</option>
</select>
</form>
any ideas why the above wouldnt work?
Chris
the name of the form is "sortform"
so the onChange code:
should be:
onChange="document.sortform.submit();"
the onchange code is telling the form to submit.
Hi Jason, thanks again for the support. still not working though. I must be missing something else in the code. as it just doesnt do anything - I had thought already about using the form name on the onchange code.. from the code i showed before would there be anything else i need to add like a hidde form element or a hidden submit code or anything like that? im guessing its going to be so obvious once I know. but just cant see it.
Chris
please send a copy of the p[age and a link where i can see the problem.
Hi Jason, I just uploaded a modifyed version of page (the actual page was password restricted and using framebuilder plugin as links on the drop downs).
here is the testing URL: test.php
I have provided also regular text links for sort to demonstrate that I can get sort functionality working without drop downs. also its odd as the drop down sort seems to ONLY work if I "first" click on the regular price sort link text. but the sort drop down wont work unless you first click on that price text link. so something odde there.
and the search drop down dont work at all - but i know its not set up but i just a bit stuck on how to finish that as it was using the variable name "WADbSearch1" in the original submit button version of the page.
attaching the file as well
for the search form:
Change the name of the select list to ProductCategoryID
<select name="ProductCategoryID" class="input-med" id="ProductCategoryID" onChange="document.filterform.submit();">
and add a hidden element named WADbSearch1
for the sort form, the value of the options should be the name of the columns, instead of:
<option value="test.php?sort=ProductSKU" >SKU</option>
use:
<option value="ProductSKU" >SKU</option>
then set the method of the form to get:
<form method="get" name="sortform">
still not working :(
here is the exact code for search:
<form action="../../account.php?page=manage-products" method="post" name="filterform"><input name="WADbSearch1" type="hidden">
<select name="ProductCategoryID" class="input-long" id="ProductCategoryID" onChange="document.filterform.submit();">
do {
<option name="WADbSearch1" value="<?php echo $row_rsCategories['CategoryID']?>"<?php if (!(strcmp($row_rsCategories['CategoryID'], $row_allProducts['ProductCategoryID']))) {echo "selected=\"selected\"";} ?>><?php echo $row_rsCategories['CategoryName']?></option>
} while ($row_rsCategories = mysql_fetch_assoc($rsCategories));
$rows = mysql_num_rows($rsCategories);
if($rows > 0) {
mysql_data_seek($rsCategories, 0);
$row_rsCategories = mysql_fetch_assoc($rsCategories);
</select>
</form>
here is exact code for my sort:(not i added the "../../account.php?page=manage-products" as its part of my template to display the page.
<select name="sortfield" id="select" onChange="document.sortform.submit();">
<option value="../../account.php?page=manage-products&ProductSKU" >SKU</option>
<option value="../../account.php?page=manage-products&ProductName" >Name</option>
<option value="../../account.php?page=manage-products&ProductPrice" >Price</option>
<option value="../../account.php?page=manage-products&ProductStock" >Stock Level</option>
<option value="../../account.php?page=manage-products&ProductLive" >Live</option>
<option value="../../account.php?page=manage-products&ProductAvailable" >Availability</option>
<option value="../../account.php?page=manage-products&ProductPopularity" >Popularity</option>
</select>
</form>
1) the WADbSearch1 need to have a value:
<input name="WADbSearch1" type="hidden" value="search">
2) the option element cannot have a name:
remove the name attribute from the option code
for the sort form:
the page name should not be part of the select list option, only the name of the column to sort:
to pass the page=manage-products variable in a form that uses the get method, you need to use a hidden element:
<input name="page" type="hidden" value="manage-products">
