Is a Horizontal Drop Down Menu Possible?
Thread begun 4/26/2012 1:12 am by elspeth383646 | Last modified 4/26/2012 7:09 am by Jason Byrnes | 959 views | 1 replies |
elspeth383646
Is it possible to create 'horizontal' secondary menus as well as 'vertical' secondary menus? eg
Home Services
Planning Education Public Affairs
where Planning etc are menu items that appear when you click on Services. Do you see what I mean?
I think it is also referred to as 'Suckerfish'.
Advice appreciated - E
you would need to hand code the menu items for this to add the additional links to the same li element as the Planing link.
for example, the menu structure for the vertical secondary menus would look like this:
<li class="parent"><a href="#">Home Services</a>
<ul class="level-1">
<li><a href="#">Planning</a></li>
<li><a href="#">Education</a></li>
<li><a href="#">Public Affairs</a></li>
</ul>
you could modify that so all three are in the same LI:
<li><a href="#">Planning</a>||<a href="#">Education</a>||<a href="#">Public Affairs</a></li>
</ul>
you would also need to edit the css to change the width of the level-1 ul to accommodate all of the links at the same level.
